Here is what Mondello has to say about this:
"After the clearances are checked on all the rods, install the center
thrust bearing and torque to 25 lbs.; tap on each end of the crank with a
heavy brass or hard rubber hammer. Use a small piece of wood and a metal
hammer , if this is all you have , to center the thrust bearing. Increase
the torque in 25 lb. increments until you reach the recommended torque
values, tapping the crank back and forth with each torque increase.
Using a pry bar, pry the crankshaft forward in the engine and measure the
clearance (with a feeler gauge) between the crankshaft and the bearing and
record the clearance. The clearance should be between .004 and .010. When
you do your final assembly, repeat this procedure torquing all the caps in
25 lb. increments, until recommended torque values are achieved. If you do
not center the thrust bearing in an engine, premature crankshaft failure
may occur."
This seems very straight forward so the secret must be in the $300 to $700
crank preps.
gene
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
may occur."
crank preps.
gene
mr.erf
