Modulator
Nov 8, 1999
150
"OK, it's kinda vague, but it basically says that you can only raise or
lower the shift points 2 - 5 mph. Turning the screw clockwise will make it
shift later and crisper. Turning counter-clockwise will make it shift
earlier and softer. One full turn of the screw will change the modulator
pressure by 2 - 3 psi. What it doesn't say is how many times you can or
should turn the screw... I'd maybe try turning it clockwise one full turn
and see what happens."
Found this at: http://www.toronado.org/mod.htm Has anyone tried
this??????..........Terry
Terry & Diane Skinner
Webfooted in Washington
