Those are good vacuum numbers. Have you replaced the modulator?
The purpose of that three-port vacuum device (called the TVS, or thermal
vacuum switch) is to switch the vacuum advance from the distributor from
ported vacuum (taken from the carburetor) to manifold vacuum when the
engine starts getting too hot. This increases idle speed and the more
advanced idle runs cooler. It should have a hose from the carb, another
hose from a fitting on the manifold, and a hose to the vacuum advance on
the distributor.
The modulator should get vacuum directly from the manifold. It could be
teed into the vacuum line from the manifold to the TVS.
But the readings you report look correct to me, so as long as they aren't
changing when the engine gets hot, I don't think that's the issue. It's
worth me saying it that way, though, since you report that the problem gets
worse as the engine warms up. You could always connect the modulator
directly to a fitting on the manifold and be sure that isn't the problem.
Rick "fickle finger of fate pointing to the modulator" Denney
> Ok, so this shifting issue is still happening. Put the new modulator on,
> tested the vacuum at modulator and it appear vacuum is good. 16# at idle, 20
> coasting, near zero at exceleration. Shifted very smothly when first
> warming up and then after it ran for awhile the issue between 2nd and 3rd
> started
> up. It kept popping out of 3rd down to 2nd and would hold on second till I
> manually shifted up to 3rd. Got back to the house and unplugged the kick
> down at right side of modulator and symptom still continued. So not sure
> whats next. Is it time to call Danny Dunn, or take it to a local
> transmission
> shop?
Rick Denney
73 x-Glacier 230 "Jaws"
