As promised here is what Mobil's engine oil analysis report will give you.
Physical Data:
Viscosity @ 100C in CST
Water as a % of Vol
Fuel as a % of Vol
Solids as a % of Vol
Fuel Soot as a % WT
Oxidation as A/cm
Nitration as A/cm
Elemental Concentrations in parts per million (PPM) by Weight:
Silicon
Iron
Chromium
Nickel
Aluminum
Tin
Copper
Lead
Silver
Sodium
Boron
Phosphorus
Zinc
They also give you their written evaluation of the oil. If excessive wear
is or is not a concern they will tell you whether or not you need to take
action\ resample etc.
Bob Neeb
Michigan
Eleganza II
Physical Data:
Water as a % of Vol
Fuel as a % of Vol
Fuel Soot as a % WT
Oxidation as A/cm
Nitration as A/cm
Silicon
Iron
Chromium
Nickel
Aluminum
Tin
Copper
Lead
Silver
Sodium
Boron
Phosphorus
Zinc
Bob Neeb
Michigan
Eleganza II
