Arch, we must run in the same circles. I just bought mine. By the way, Sears
has them, or their hardware store had one here. I paid $39 -10% sale. I like
tha fact that all the fittings are brass. I asked the radiator shop where they
fixed my A/C when I lost it in Barstow Ca. The outside temp was 116 and the
water was running a high in the radiator. I was worried about the heat, the A/C
and the engine, but not to worry, the A/ C failed so I had to run without it
anyway. In his opinion the misters do work and work well. He suggested that
not only does it help the engine it helps the A/C run better. I plan on
installing mine for next year. For those of us who run through the desert in
the middle of summer, I think having the misters is a good idea. For those in
other areas, the current fan clutch and system is adequate. I have not had a
problems up to now, until that trip when the heat was so unbearable I hurt. The
problem even caused my onan not to come on. What a hot few hours until the sun
came down.
Arch, what I do suggest is that you run your water through a set of filters to
get out as much crud as you might have in the water system. I have a set of
filters that I use when I fill up the water tank. I plan on doing the same
thing. The system 2000 was very reasonable and a good quality product.
Al
> Folks I sent this afternoon at 2 PM. It has never come back to me
> so I am resending it Arch
> GMCers
> Good news. I got my mister kit today. It is the Arizona Mist 2000 System.
> It can be seen at www.azmist.com I am very favorably impressed. The
> kit includes 6 all brass connectors. 6 brass and stainless steel mister
> heads. Tubing and other stuff I probably wont use. It takes no tools to
> assemble. Tubing just pushes into brass connectors. There is a locking
> mechanism and O ring to seal against tubing. Nice thing is you can take
> it back apart because you can depress the locking mechanism. I first put
> on a connector and hooked it to my household water pressure (about
> 80 PSI). The spray from the nozzle was more like a fog instead of mist.
> Very fine mist of fog. No leaks at all. Then I disassembled everything and
> to the motorhome. The other nice thing about this system is that it uses
> standard 3/8 inch plastic line-----which is what I had run down the side
> wall of the motorhome. Put on one mister head to see if my water pump
> had enough volume and pressure to run one mister head. WAHOO!!
> The pump only runs for 4 seconds every 2 min. I do have a small
> accumulator tank on my pump. This means the pump will run only about
> once every 20 seconds with all 6 heads on it. I dont intend to run this
> system all day but it is nice to know that with all six heads it is only
> going to consume 3 gallons per hour. The fog was just as good running
> on the motorhome as on house hold pressure. The only difference that I
> could see was that the cone of mist coming out on house pressure
> kept its shape longer than on motorhome pressure. I do not see this
> as a problem. At 60 miles per hour it is going to mix up a lot anyway.
> Things I like:
> System goes together with no tools.
> Mist heads have O rings on them so you only screw them in hand
> tight into the brass connectors.
> Since mist heads come out easily they can be cleaned and removed
> for the winter. With heads removed it will be easy to blow out the water
> for the winter.
> Lowes was able to special order this kit for me for $46 and pennies including
> shipping. Thats over $100 cheaper than the kit recommended in two places
> in this months Motorhome Magazine.
> Thats what I know and what I am doing. This does not mean you should
> do the same.
> Take Care
> Arch 76 GB IL
came down.
Al
> GMCers
> Things I like:
> for the winter.
> do the same.
> Take Care
> Arch 76 GB IL
