So true. It’s like remodeling a old house
Chaplain Randy Hecht
Chaplains are ready to Listen when you're ready to talk.
> Having ones coach in a shop a long term does not mean anything as were not
> mind readers and also do not like customers saying were picking on their
> coach.
> Some of you do not realize how poorly your coach is when it comes in to a
> shop.
> No way can one locate ALL the defects.
> I know ALL the GMC shops will agree with me. We do spend time communicating
> with other shops weekly.
> On Sun, Jun 16, 2019 at 8:12 AM John R. Lebetski via Gmclist <
>> Even If the front exhaust system is leak free, it still can be noisy in
>> the cabin if cheap single wall casing mufflers were installed by the PO. GM
>> used dual wall construction for durability, safety and noise contamment. I
>> removed cheap mufflers and replaced them with correct sized dual wall
>> mufflers made in Canada by my suplier I have used for other projects.
>> Huge difference in radiated sound. Conversation can be at living room
>> Levels. I can offer these if there is interest. The NAPA/Walker mufflers
>> in the exchange fit fine to get by but one of our members had one "oil can)
>> the top casing until it failed and burnt the floor. Beware.
>> Are the fumes you are smelling exhaust or oil or fuel drips on the hot
>> engine? You need to dertemine and correct this. Also Wes from Cinnabar
>> wrote
>> an article on this years ago. I follow his advice. You need to create a
>> positive fresh air pressure in the coach. That means windows closed and dash
>> fan on 2-3-4 on fresh setting not Recirculate. The fresh air enters the
>> grill and into the fan under additional pressure at highway speeds. This
>> prevents drawing in fumes and holding tank odors because of positive
>> pressure in the cabin.
>> If gasoline fumes, often the fuel line into the Qjet gets "wound up" when
>> tightened. It then springs the nut loose slightly with heat cool cycles.
>> Even one drop per min evapoating will give a big fuel odor in cabin. Also
>> have them check all the evaporative emissions hoses and charcoal canister
>> for proper operation
>> John Lebetski
>> Woodstock, IL
>> 77 Eleganza II
> Jim Kanomata
> Applied/GMC, Newark,CA
> jimk
> 1-800-752-7502
