Minor non-emergency problem
Matt Colie
11,101
807
113
South East Michigan near DTW
We are in Stanwood MI with the Great Lakers. It is cold. I was expecting that.
What I was not expecting was the air heater in our Carrier roof top unit to do the Roman Candle effect.
I can buy propane on site.
Carrier is out of the transport business, a few years now.
Does anybody have a line on someone that may have NOS of the heater?
The nearest "big box store" has cube heaters. I carry two of them and
seldom use the roof air heater because those are quieter and better
located. Plus they cost about 1/2 the a/c heating element.
JWIP,
> that.
We use the cube heaters also. Carry two of them in the cooler seasons, but never used more than 1. Even in GA last year when it was below freezing at
night and didn't get out of the 30s during the day, we still only needed 1. Works better than the heat strip since they have better temperature
control. Of course, we have 2 adults, 3 kids, and a dog or two in the coach, so there is a lot of body heat! But considering we long ago removed the
furnace, those cubes have never let us down. We just make sure we are plugged in to 50 amps in case we need both.
Thinking we will test them again coming up when we head to D.C. to honor my wife's grandfather in his Arlington burial. That could be a cold trip!
Thanks,
Jeremy Knezek
1976 Glenbrook
Birmingham, AL
Matt,
I got my heat strips from camping world.
See if these are for you.
http://tinyurl.com/zhuq4xs
or
http://tinyurl.com/zoewbss
Check with them I think that you have a store close where you live.
J.R. Wright
GMC GreatLaker
Newsletter Editor/Publisher
Tech Editor
78 Buskirk 30' Stretch
75 Avion Under Reconstruction
Michigan
> Matt
On a similar note. Hit 18 deg in SD and just before bed Suburban started blowing only cold. Opened front and that doesn't get you much. Moved stuff
under bench away from cold air return (that should not effect sail but may have overtemped) then turned off and back on gas valve and she has been
working great since. Poured 2 gal pink down the toilet to mix with maybe a few gal black water and left fresh water normal. All was good.
Source America First
The two eBay listings for Carrier heat strip
222279588897
182016538398
Dennis
Dennis S
73 Painted Desert 230
Memphis TN Metro
Dennis,
Thanks,
For some reason, the 50$ part didn't come up in my search.
> Matt
> 222279588897
> 182016538398
> Dennis
