I thinkn this side and both of the tires get the worst of the wear
probably due to, and it only takes once. Hit a curb in a right hand
turn and you are out of alignment. You may not be able to see the
alignment but it is out. The front rear wheel will then be pointed out
just a wee bit and drag instead of going full straight. Just my
thoughts, I should say I hear this in a seminar and in this case I
looked at the tires that had wear on them from that point. You can
continue to rotate these tires and it will help but I think we need to
have a seminar and learn how to aligne all 6. I am a believer in this
but have no knowledge to do it. Chuck
