Microwave location - cooktop exhaust fan
ken harland
292
1
Now that I'm back to working on my coach, I moving forward on ideas I had from the beginning. I want to remove the stove/oven and replace with a two
burner cooktop but instead of putting the microwave below the cooktop which I believe both the wife and I will hate, I am considering putting it in
the cabinet that presently houses the fan/light assembly.
I'm sure someone has already done this so my question is what did you do about the exhaust fan? We never have cooked much in our RVs and I don't
expect that to change but I do cook breakfast most days and that includes frying bacon.
And please pass along suggestions for two burner cooktops while you're at it.
TIA,
Ken
1978 Eleganza II
Set your fantastic fans to exhaust and they will change the air over in a GMC in no time. One of the first things I took out, in search of more
storage, was the exhaust fan. Of course I also have no propane, so I don't have to worry about fumes accumulating (though how the exhaust fan would
help with that I'm not real sure). But we cook bacon and everything else in the coach. We just set all the fans to exhaust and let it get sucked out.
Thanks,
Jeremy Knezek
1976 Glenbrook
Birmingham, AL
This upgrade has been done many times. Here is how we did it:
http://www.gmcmhphotos.com/photos/g3022-interior-restoration.html
and
http://www.gmcmhphotos.com/photos/g3972-kitchen-vent-hood.html
Believe me that your wife does NOT want to be on her knees to look into a microwave.
J.R. Wright
GMC GreatLaker
Newsletter Editor/Publisher
Tech Editor
78 Buskirk 30' Stretch
75 Avion Under Reconstruction
Michigan
> TIA,
> Ken
> 1978 Eleganza II
> and
> Regards,
> J.R. Wright
> GMC GreatLaker
> Tech Editor
> Michigan
Thanks! Was there a thread discussing it, I'd like more info on your exhaust fan.
1978 Eleganza II
Lots of undercabinet microwaves have buit in exhaust hoods that can vent out the back. They also have dimable lighting. This solves both issues of
venting the cooktop and providing lighting. You just sacrifice 12V opperation.
Source America First
> and
> Regards,
> J.R. Wright
> GMC GreatLaker
> Tech Editor
> Michigan
How did you handle the venting of heat from the convection MW? Is it enough to just leave an air space or did you vent it to the outside? TIA
Patti & Jerry Burt
73 Gmc 26' Canyon Lands -
Photos - http://jburt.smugmug.com/GMC-Motorhome
Lots of upgrades but lots to do to make it ours.
Members: FMCA - GMCMI - GMCWS - Pacific Cruisers - 49ers
Ken:
Here is the way I did my Microwave Install above the stove. Look through the entire album to get an idea what I did. For some reason I cannot find
the photo directly on to the finished job but I will find it or take another in the spring (Things are in storage)
The photos should give you some ideas as you tackle your own project. Good Luck.
http://www.gmcmhphotos.com/photos/g7014-microwave-above-stove.html
John and Cathie Heslinga
1974 Canyonlands 260
455, Manny tranny and 1 ton, 3:70 LS,
Red Seal Journeyman, DTE, BEd. MEd.
Edmonton, Alberta
My 23' has the microwave hanging under the cabinet over the sink. The exhaust fan works just fine beside it and over the stove. I took the (huge)
Dometic microwave out of the 26' when it failed, and put a cheeeep Haier ($40) in its place. The plan is to build a shelf for the smaller unit and a
plenum under it for a stove top exhaust hood. There's already a vent behind it in the outer wall. Then I'll take some plywood with a matching veneer
and close up the opening with a curout for the front of the Haier microwave. Sometime this year I hope. Meantimes, as sonmeone said, set both fans
top exhaust and even without a vent, cooking odors and such vacate the coach very quickly.
The built-in induction cooktops were prohibitively expense when I shopped for one a couple of years ago, so I just replaced the entire counter top and
got a couple of portable induction cooktops to fulfill my non-microwave cooking needs and we can store them in the cabinet space created by removing
the oven. If we need an oven we have the NuWave infrared/convection oven that also gets stored in that space when not in use. You can get a pair of
the NuWave portable induction cooktops for about $120 online last time I checked. Cheaper than that at Wal-Mart on the right day. Then you have the
whole counter for use when you're not cooking, which is most of the time for me. In fact the only thing I have cooked so far was some TV dinners in
the nuke and coffee.
I put the nuke in the compartment above the drawers, just needed a little spacer underneath to raise the door over the height of the fiddle. I
screwed it down from underneath so it stays put during exciting driving conditions.
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
G'day,
Look what I stumbled on!
https://camec.com/major-appliances/rangehoods/camec-12v-flush-mount-range-ho
od.html
And
https://camec.com/major-appliances/rangehoods/camec-rangehood-12v-2-speed.ht
ml
The Pedantic Mechanic
USAussie - Downunder
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Johnny
Bridges
Sent: Thursday, January 19, 2017 2:14 AM
Subject: Re: [GMCnet] Microwave location - cooktop exhaust fan
very quickly.
G'day,
od.html
And
ml
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Sean
Kidd
Sent: Thursday, January 19, 2017 4:55 AM
http://www.gmcmhphotos.com/photos/data/6156/medium/DSC03304.JPG
I used an over the range microwave an created a plenum behind to "duct"
fumes out original opening
Sean and Stephanie
73 Ex-CanyonLands 26' #317 "Oliver"
Hubler 1-Ton, Quad-Bags, Rear Disc, Reaction Arms, P.Huber TBs, 3.70:1 LSD
Honda 6500 inverter gen.
Colonial Travelers
We vented the heat generated when using the Convection oven mode out the top and back to the inside. The actually time that you really use the convection function is very, very small. In our first coach which the pictures were from we used the convection feature maybe 2 to3 times a year. As for the vent under the convection/microwave over the 2 burner stove that is a 12VDC Bronan RV vent hood with lights that I modified to fit under the MW/Conv unit and above the 2 burner. The vent fan uses the same vent path that the stock vent hood did.
J.R. Wright
GMC GreatLaker
Tech Editor
Michigan
>> and
>> Regards,
>> J.R. Wright
>> GMC GreatLaker
>> Tech Editor
>> Michigan
> Patti & Jerry Burt
> J.R. Wright
> GMC GreatLaker
> Tech Editor
> Michigan
Thanks for the info. Looking at the installations others have provided, it looks fairly simple to adapt the original vent system to exhaust the heat.
My current plan is to mount a convection MW over the stove area and eliminate the stove-top/oven. Similar to SeanKidd's installation only without the
burners.
Patti & Jerry Burt
Thanks. That's the way I propose mine to end up.
John,
With your microwave installation I'd be worried about heat buildup in back -- especially for longer cooking jobs. That's why built-in microwaves usually exhaust to air the front. Have you had any problems with that?
Steve Jess - Tucson, AZ
Mid-day/PM newscaster
Arizona Public Media
Sent: Tuesday, January 17, 2017 10:17 PM
Ken:
Edmonton, Alberta
Gmclist Info Page - list.gmcnet.orghttp://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org
list.gmcnet.org
To see the collection of prior postings to the list, visit the Gmclist Archives. Using Gmclist: To post a message to all the list members, send email ...
> This is how I solved the microwave location problem
> http://www.gmcmhphotos.com/photos/g3832-microwave-lift.html
> Jim Wagner
> Brook Park, oh
> 1976 GMC500
> 1971 Vega355
> 1969 Corvette383
Thanks Jim, that's very creative but I'm hoping to gain the storage space from removing the oven.
> J.R. Wright
> GMC GreatLaker
> Tech Editor
> Michigan
Thanks, that's a great idea.
1978 Eleganza II
Steve:
While it does not show, The rear of the Upper cabinet is open, allowing the microwave to vent into the cabin of the coach. I cannot say I've had a
problem with heat build up, because Ive never noticed or looked closely for a problem. The Cabinet is not tight against the wall so there is a lot of
space for venting. I could place a nice looking grills rather than the solid panels that are in the face plate to solve those problems if needed.
I purposely did not place grills in the lower panels under the cabinet to avoid stove heat from going up into the cabinet, but they could be grills
too.
Hope that helps.
Edmonton, Alberta
