Ok Microlevel is ready to go.
For those that don't know, it's a microprocessor based true heigh measuring ride height controller for the GMC motorhome.
It was developed for the GMC on the GMC and only for the GMC. It's not a hack of a generic solution.
It operates a lot like the stock systems and adds 3 new features.
1. Campground leveling. Push a button and it levels.
2. Push button height calibration. Since it uses a microprocessor and true height sensors, setting the ride height is just a few button presses, no mechanical adjustments.
3. RF remote, raise or lower either side from inside or outside the coach, great for dumping, changing tires or any other maintenance.
Cost is $895 USD
For that you get:
* Microlevel Controller
* 2 Valve blocks ( 4 valves )
* 2 ride height sensors with custom brackets
* Sensor wiring harness
* Key Fob 4 channel RF remote
* Dimmer
* Email tech support
* 2 year full replacement controller warranty ( unless you obviously abuse it! )
Here's the sales brochure
http://www.gmcmotorhomemarketplace.com/vasilakes/microlevel_intro.pdf
Users manual
http://www.gmcmotorhomemarketplace.com/vasilakes/microlevel_install-operation.pdf
Wiring diagram
http://www.gmcmotorhomemarketplace.com/vasilakes/microlevel_wiring.jpg
Cost is $895 USD
For that you get:
* Dimmer
Users manual
Wiring diagram
