message times - Attn: Patrick
tim dawson
778
Looking at the headers as this was sent to me, it is apparent that a few sites
along the way are using GMT:
>From gmcmotorhome-owner-tadawson=tpcsvc.com Mon May 8 09:16:46
2000
Received: from mailinglists.org (server1.mailinglists.org [63.160.175.18])
by zippee.tpcsvc.com (8.9.3/8.9.1a) with SMTP id JAA07672
for ; Mon, 8 May 2000 09:16:45 -0500
Received: (qmail 22745 invoked by uid 108); 8 May 2000 14:16:36 -0000
Delivered-To: gmcmotorhome
Received: (qmail 22713 invoked from network); 8 May 2000 14:16:34 -0000
Received: from m2.jersey.juno.com (209.67.34.60)
by server1.mailinglists.org with SMTP; 8 May 2000 14:16:34 -0000
Received: from cookie.juno.com by cookie.juno.com for
Received: (from davegreenberg1)
by m2.jersey.juno.com (queuemail) id E7J7RDSN; Mon, 08 May 2000 10:13:25 EDT
Specifically, and server which indicates the time and then "-0000" is on GMT,
not local time, which will show the skew. If your mail server is also on GMT,
and you use pop to get mail from it, you will get the bad times. I run my
own server, and hence, the times are readjusted correctly upon receipt.
- - Tim
> To follow up on this -- I sent this message at 5:35 PM MST which is
> > 7:35 PM
> > EST. As you can see above it shows 11:35 PM so a clock somewhere is
> > off by 4
> > hours.
> > Emery
> Emery I think you've got way too much time on your hands!
> With over 100 msgs a day I have all I can do to
> read/reply/delete/forward/file/etc, without looking at the time. How do
> you do that?
> Just an inquiring mind.
> David Lee Greenberg
> GMC Motorhome Registry
> Dedicated to the preservation of the Classic GMC
> http://www.gmcss.com/registry.htm
Tim Dawson (tadawson) Owner/Engineer
TPC Services Bellnet: (972)-221-7385
Lewisville, Texas 75067 FAXnet: (972)-221-0393
"The world is complex. Sendmail.cf reflects this...."
> 7:35 PM
> off by 4
> hours.
> Emery
you do that?
David Lee Greenberg
Tim's explanation is about as good as any. I'm really no authority
of the complexities of mail routing on the web.
Patrick
> 2000
> - Tim
> > > 7:35 PM
> > > off by 4
> > > hours.
> > > Emery
> > you do that?
> > David Lee Greenberg
Patrick Flowers
Mailto:patrick
The GMC Motorhome Page
http://www.gmcmotorhome.com
