Mercedes Cooling Fan temperature settings
jack christensen1
264
Since the previous post has now extended to 2 pages, I'm starting a new post with a focus on fan temperature control.
I've installed a simple PID temperature controller to turn on the fan and provide the option of varying the turn on and off temperature settings
easily. The output of the controller is a pulse width modulated signal based on how far the temperature is from the set temperature, not just a hard
"on" or "off" over a wide range. Based on my intuition and suggestions from the others in the previous posts, I set my unit with a target cold shutoff
temperature of 160 degrees. I then set off on a trip to the GMC 49ers rally in Sacramento. The weather was hot and I was running the air
conditioner.
Per the instructions that come with the kit, I had installed my temperature probe on the passenger side midway between the top and bottom the the
radiator and alongside of the temperature switch provided in the kit which, according to the kit, is set to turn on at 210 and off at 195.
What I found was, that with the AC running, when the temperature at my probe rose to 130 degrees, the water temperature reported from the engine
output to the radiator was over 220 degrees. I'm not sure what it would have been if my setting of 160 degrees was reached as I turned on the fan
manually which quickly brought the temperature at the probe's location down to 100 degrees and the engine water outlet temp to 195.
What this says to me is that the temperature switch in the kit is inappropriate for this location as it would never turn on....well until after bad
things happened. At its current setting it would probably best be installed where the water enters the radiator.
For my drive home, I set the target shutoff of the controller at 115 thinking I could see how the fan behaved when being switched on and off at a rate
inversely proportional to the temperature over 115. Unfortunately we were having rain and it was cold, so no AC, and the radiator output never
reached 115. So more testing needed.
I did come to the conclusion that the fan should be sent a pulse with varied "on" signal until the temperature at the probe drops to around 120.
Also, based on how the temperature at the probe varied with the AC on and off, I can see why modern cars with electric fans are designed to have them
turn them on at some level when the AC is running.
Jack Christensen - K6ROW,
'76 Glenbrook/Clasco - "The Silver Bullet",
Sebastopol, CA
Yes indeed, Capt. Jack 8)
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
I’m of the old school .
I tend to feel that engine temp is ewhere I want the fan sensor to Be. R
I will be conferring with people
On Mon, Mar 16, 2020 at 1:18 PM Terry via Gmclist
> Terry Kelpien
> 73 Glacier 260
> Smithfield, Va.
http://www.gmcrvparts.com
Thermostat controls engine temperature.
Excess heat transferred to radiator.
Fans shed heat from radiator.
Consider a remote heat transfer station.
Engage thinking... 8)
Terry Kelpien
73 Glacier 260
Smithfield, Va.
In the automotive world ( the way it's done) the electric fan On temp needs to be at LEAST 10F over the stat temp rating. Usually a bit more because
there is usually a 10F spread in the on to off range to prevent short cycling (hysteresis). This is using engine coolant out temp for ref. A
separate issue is AC. Some turn the fan on with each compressor turn on. Some turn it on low with compressor (low meaning low speed via resistor or
low by 1 of 2 fans) then to high when over a certain hi side pressure or engine temp is reached. What is different here is it takes time for the
clutch to move fluid to the non working chamber, so I would think the Off temp could be closer to the On temp with no hysteresis occurring as fan will
continue to run for roughy 2 minutes after Off command causing a built in overshoot.
The stat only controls minimum temp. Setup might work in warm weather, but will run too cold "on the stat" when cooling conditions are better. But
180 is considered an "alternate temp" stock stat on some GM. (Unlike the 160 the Jegs guys go for). The lower the stat temp, the more potential
thermal swing with different conditions. In theory temp swings are bad for gaskets as metals shift. . Probably won't hurt but could keep oil too cold
in cold weather to boil water out of oil. I'm guessing these clutches are more go/no go than infinitely variable.
Jim K wants to use the temp at the engine to control things. Some of the Fuel Injection systems (maybe all) allow that. Specifically the FiTech
system has that programmable capability via it's temperature sensor usually located in place of the Christmas Tree which would address Jim's concern.
It's strictly on/off with no inherent ability to vary the fan speed, much like the temperature switch provided with the fan kit. It is adjustable,
however, unlike the temperature switch in the kit.
Sebastopol, CA
I have been watching this thread with a curious intent. Not sure why it's
getting all this attention. The fan has evolved through the years. Started
out being driven by the water pump, and only had a couple of blades. Some
of the very early ones were used on engines that were not even equipped
with water pumps, and were known as thermo-syphon systems. As the engine
heated the coolant, it would rise to the highest point, pulling the cooler
water along with it. That is how the coolant circulates. O.K. for the low
compression, low speed, low horsepower engines of the day. Not very
efficient. Crank driven fans helped with cooling chores. Through the
decades, water pumps, honeycomb radiators, copper and brass materials were
used. Pressurized radiators raised the boiling point of the coolant, and
improved circulation as a result. Along the way, more blades were added to
the fans, along with shrouds and deflectors.
Pretty soon, designers realized that those multi-bladed fans robbed a
bunch of power from the engine, and were very noisy to boot. Thermostats
entered somewhere along the way. Some bright person came up with a self
controlled viscous coupling ( clutch fan) that defied all laws of fluid
dynamics. The fluid was very liquid at cooler temperatures, and became more
thick with a rise in temperature. Unique among fluids. No moving parts.
Bonehead simple. Worked quite well.
So now, we are trying to re-invent the wheel. A difficult undertaking?
Fools errand? Heck, I don't know and am reluctant to speculate on which it
is. It is a tall order in any event. Guess I'll just wait n see.
On Mon, Mar 16, 2020, 8:05 PM Jack Christensen via Gmclist <
> concern.
> Sebastopol, CA
Let's try this again. The thermostat is a cheap and marginally accurate device. For this reason I usually put the original and the new thermostat in
a pan of hot water and heat it. I observe the open and close operation while reading the the water temperature. The thermostat does NOT magically
open fully at the desired temp. It starts to open at around 180 or 195 and SLOWLY opens wider if the temp continues to rise. Mean time whether open
or closed the water pump is circulating the coolant throughout the engine to keep the entire engine at the same temperature. That is what the bypass
hose does near the thermostat and to some extent the cabin heater does too.
When the thermostat is open a limited amount of hot coolant above 180 or 195 is sent from the engine to the radiator. At the time, the same amount of
cooler coolant is returned to the engine to be mixed in with the hotter coolant already there. How much coolant is exchanged is determined by the
thermostat.
So the question now is how does that replacement coolant get cool enough to keep the engine at around 195 or 180? Well that is determined by the
amount of and temperature of the air going through the radiator. We really do not care what temperature the coolant is as it returns to the engine,
EXCEPT when is is not low enough to mix in and lower the engine temperature to the desired 180 or 195.
Notice that we have not even mentioned the fan at this point. It can be zero degrees or 100 degrees outside and the coolant can be running at a
usable temperature. The thermostat will determine how much cooler coolant will be needed to keep the engine temperature at the desired 180 or 195
degrees.
Only when the returned coolant does not have the capacity to cool the engine sufficiently does the fan get involved. So I still maintain that you
determine the maximum temperature that you want the return to the engine coolant to be at and set the fan turn on point there or maybe 5 degrees
lower. You only want the fan running when it is necessary and you do not want the slowness or variable temperatures that the thermostat runs at
affecting the on again / off again cycling of the fan.
You can have the soap box back now.
One thing to remember when you use a pulse train to operate the valve in the fan clutch. Since the fluid is fairly viscous the valve isn't going to
snap open and closed as a solenoid would. It will essentially integrate the pulses and open partially, the amount of opening being relative to the
pulse width. You could consider the setup with an on - off temp switch as pulse controlled with very long pulses. There's a range on the M-B fans
which will turn it from about ten percent of shaft revolution to about 90 percent of revolution. Correlate this range to either engine temp or
radiator outlet trem and you can use the amount of air flow needed without overdoing it.
If you use an analog meter, you can see this action if the pulse repetition rate is fast enough. The needle will fluctuate around the average
voltage.
> I have been watching this thread with a curious intent. Not sure why it's getting all this attention.
> Pretty soon, designers realized that those multi-bladed fans robbed a bunch of power from the engine, and were very noisy to boot.
> Thermostats entered somewhere along the way. Some bright person came up with a self controlled viscous coupling ( clutch fan) that defied all laws
> of fluid dynamics. The fluid was very liquid at cooler temperatures, and became more thick with a rise in temperature. Unique among fluids. No
> moving parts. Bonehead simple. Worked quite well.
> So now, we are trying to re-invent the wheel. A difficult undertaking? Fools errand? Heck, I don't know and am reluctant to speculate on
> which it is. It is a tall order in any event. Guess I'll just wait n see.
> Salem, Oregon
Jim,
As usual, your observations are effective. But you seem to have missed two things....
The temperature controlled fans were installed for Emissions First and CAFE Second. (The five bladed non-harmonic fan was a noise issue.)
The real reason that the new fan control is of interest is that (like the tuning of clutch springs) making these work seems to be a lost art.
When I have Chaumière sitting on tires again, I plan to do more experiments with the fan control mode and set points, but right now, that is nowhere
near the top of my task list.
Oh, and KenB, I am sure that a few more now understand more than they did just a little while ago.
Matt, I didn't mean to imply that high interest in cooling fans was
misplaced use of research and resources that might be better applied to
some other cause. Far from it. I am among those who are quite interested in
where this is headed. My 2006 Chevrolet Trailblazer with the Vortec inline
6 cylinder has an old school viscous clutch fan, engine driven.
However, all my other vehicles have computer regulated, electric motor
driven fans. My Chrysler PT Dream Cruiser is a modern marvel. 4 cylinder,
dual overhead camshaft, 4 valves per cylinder, Turbo Supercharged,
Intercooled, fuel injected engine displacing 2.4 Liters. It puts out 220
SAE net horsepower. The car weighs about 2400 pounds wet. I call these
kinds of cars, "pocket rockets". The computer manages everything from cabin
temperature to transmission shift points to boost pressure, to cooling fan
tip in points as well as speed. All designed as part of the package. And it
works very well. Hardly ever have to even open the hood. Can't get my big
hands in there to fix anything, even if I had too. So complex, old school
diagnostics no longer apply.
Applying this level of technology to a GMC is a tall order. Many of
our coach owners cannot even check their own transmission fluid level
correctly. I am not a luddite by any means. High tech has it's place. I am
just standing back a couple of steps and observing with great interest.
Hope something useful to all of us comes from all this.
On Tue, Mar 17, 2020, 7:55 AM Matt Colie via Gmclist <
> on
> see.
> > Jim Hupy
> > Salem, Oregon
> Jim,
> two things....
> is nowhere
> Matt
The early Trailblazer fans were viscous clutch but were controlled by a PWM pulse from the computer. After replacing several of those for many
hundreds of dollars, I've since swapped over to the old school viscous clutch used on the newer trailblazers. Its simple but it doesn't seem to fail
as easily. I went through at least three of the PWM fans in the first 200K miles. I've since put another 160K on the old school fan with no more
issues. I just learned to ignore the service engine light. The controller doesn't like the fact it doesn't see signal from the fan.
Jerrod Winter
1977 Palm Beach
Green Jelly Bean
Twin Cities, Minnesota
Bill,
That's a good question. I'm wondering myself after some quick partial tests while moving. I'm been expecting that the valve opens fully for a short
time based on the pulse width, but it doesn't seem to take a very long pulse for the fan to come on fully. There may be some additional filtering
needed, or perhaps a dc voltage proportional to the pulse width. The experiment continues...
Sebastopol, CA
It will move part way. This because it's moving in a viscous fluid. This assumes the pulse repetition rate is greater than about ten times the
opening rate.
