Mascerator pump
homebase1
476
Remember you can pick your friends but not your GMCnet'ers !
Whoever is in charge of stupid questions today, would you give this
one a go.........
Last year, when wandering around ( I'm short) under my '77 Kingsley,
I discovered this pump looking thing attached to my holding tank by a
rubber hose. One end was held by the hose and the other by a
combination of a coat hanger and a knotted tube. No electrical wires
dangled in the immediate vicinity. As it didn't drip, drag, or
spark, and being no relation to Sherlock Holmes, I left well enough
alone ! It appears the mystery has been solved !!
OK...now the questions..
Assuming, like everything else, it needs a total rebuild; how many
different manufacturers were there and what is part availability?
What was the usual set-up? Where was the power switch generally
located, where was the hose connection, and what size and length
discharge hose is required ?
And now for the best....Under what circumstances would one use such a
"device"?
Thanks
Mike B
Just as an afterthought, and being a Scotsman, what are these things
worth? ( Imagine a Scotsman interested in costs and driving a GMC!)
> one a go.........
> "device"?
> Thanks
> Mike B
> worth? ( Imagine a Scotsman interested in costs and driving a GMC!)I
just completed an install on a macerator pump this weekend. I bought
mine (JABSCO) through a Marine supplier in Houston (about $130). If you
don't see any wires coming out of the electric motor end then they were
probably cut off. It may not be worth while fixing.
I feel a macerator is the most convenient and cleanest process of
emptying the holding tank. You attach a 3/4" garden hose to the output
end and press a button to empty it. I intalled the switch in the shore
power compartment of my "78 Kingsley.
Rich Major
'78 Kingsley
Sugar Land (Tara) Texas.
There is always the possibility that the attachment you found on Your
Motorhome was NOT a mascerator pump, but it could have been a
Thermo-San. They were an option on some years. I had portions of one
attached to my holding tank, as well as the controller attached under the
dash.
Just a possibility!!
> one a go.........
> "device"?
> Thanks
> Mike B
