>>>>Anybody have any other manual anomalies??
Gene, this would be good historical info to be included on your web site.
Paul Bartz
ok ok, lets give this a try. This is what I have so far.
For example the 73 manual says that the front axle is torqued to 110 ft-lb.
The 75-76 says 140-280 ft-lb. The 77-78 says 110-140 ft-lb not to
exceed 280 ft-lb.
The 75-76 manual says the front end alignment should be 0 to -1/4"
(toe out). The 77-78 says -1/16 to -3/`6" (toe out).
emery
Another inaccuracy. On page 6Y-45 of the X-7525A manual, distributor
rotation is
listed as counterclockwise. On pages 6Y-33 and 6Y-34 of the X-7725 manual
it is
listed as clockwise.
Dick Paterson in one of his seminars stated that distributor rotation on all
Oldsmobile engines is always counterclockwise. paul
1-8-4-3-6-5-7-2
Front of coach
| 1 2 |
| 3 4 |
| 5 6 |
| 7 8 |
Since this is from my notes, I probably wrote it there because there is a
mistake in the FSM.
HTH,
Patrick
My notes show the error to be in the distributor cap plug wire numbering,
since my 455 firing order picture is correct, as stated by Patrick.
(p.6Y-50, 75-76 M.M.)
Manual diagram shows plug wires 3 and 6 reversed.
Should be wired (in clockwise sequence) 1-2-7-5-6-3-4-8.
HTH
Fritz Washburn
any more to add ??
gene
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
Paul Bartz
exceed 280 ft-lb.
emery
rotation is
it is
1-8-4-3-6-5-7-2
Front of coach
| 1 2 |
| 3 4 |
| 5 6 |
| 7 8 |
mistake in the FSM.
HTH,
Patrick
HTH
Fritz Washburn
any more to add ??
gene
mr.erf
