Arch might be cheaper to let Mondello do the complete manifold. He has
a new process that will polish the inside of the manifold to increase
the
flow. Might be interesting to see how much it costs.
It's called extrude honing. A clay like medium with a specific
abrasive content
is forced through the manifold passages under extreme pressure. It does
an
incredible job of opening up and polishing the interiors of tight
passageways.
I believe the process is a spinoff from the aerospace industry. It is
expensive!!
A simple job of match porting the intake manifold gasket to the heap &
intake
ports yields excellent results & can be done by anoyne with a small
grinder.
Smoothing the head intake ports is not necessarily desirable as the
roughness tends
to add turbulance to the intake charge, which is good.
Steve Ferguson
San Diego
the
abrasive content
an
passageways.
expensive!!
intake
grinder.
roughness tends
Steve Ferguson
San Diego
