Makes it easy to manage wheels
Matt Colie
11,101
807
113
South East Michigan near DTW
Well, I wish I has thought of this sooner.... Look up "Wheel Dolly" at Hazard Fright.
This makes managing wheels a bunch easier.
I've owned 4 of these for more than few years. I got them to move the 6k# sailboat on a trailer sideways in the barn. Yeah, I did the bit with both
magazines and then wet sheets of PE, but that gets old fast.
Recently, I had to replace 2 shocks (one front and one rear) and I was struggling with 80# wheels to get them lined up with studs. Then I had to move
something, (if you should see my barn, this would be no surprise) and uncovered the stack of "Gojacks" as they are trade named. The LED (only
recently upgraded) in my brain finally lit. I dragged out one of them and stood the loose wheel in it and pushed it clear of the work area.
When I got done and wanted to put the wheel back, I pushed it back to the center of the hub and was going to adjust the jack, when I said to my
self,"Hey Stupid - the tire is on a jack." So, I pumped the wheel dolly until the studs were close and with the tire on the rollers, rotating it to
mate it with the studs was simple.
I just wish that I had though of this on the first wheel.
If you live in striking range and would like to borrow one or more, let me know. They aren't making anybody any money while stacked in my barn.
Pick em up, hold em at arms length, and jam em onto the studs. Ez-Pz. Whats
that, you can't lift them any more? Hmm?
What's up with that? Try it after they saw through your sternum with a bone
saw and wire it back together with wire the size of bicycle spokes. And put
you on 10 pound weight lifting restrictions for a year. Even if you were
king Kong before that, afterwards is a reality check of the highest order.
Work smarter, not harder. Leverage is your friend. I use a 2 foot long
piece of car leaf spring welded onto a piece of thick wall tubing about 18"
long, and a short piece of 4 x 4 for a fulcrum. A bit of practice, and you
are golden. Just what I do.
78 GMC ROYALE 403
> Not a bad idea!
> I just sit down with my legs under the tire and lift with my legs
> Justin Brady
> http://www.thegmcrv.com/
> 1976 Palm Beach 455
The details says that price is for 2. That would be about $5 more per jack.
> Twice the price, but possibly better quality option...
> http://www.eastwood.com/eastwood-hydraulic-wheel-dolly-2pc-set.html?SRCCODE=PLA00020&product_id=30551&adpos=1o1&creative=83580269220&d
> evice=c&matchtype=&network=g&gclid=Cj0KCQjwiLDMBRDFARIsACNmiX_bZoAddiqJB9vdNhzfyeil9RmbB1gc3ZgI7-F3AGJhL2pmCCx5FfMaAnoEEALw_wcB
> ..actually if I am reading the ads correctly, It looks like the Harbor Freight price is for a single unit, and the Eastwood price is for the pair.
> Hmmm.
Patti & Jerry Burt
73 Gmc 26' Canyon Lands -
77 Palm Beach
Members: FMCA - GMCMI - GMCWS - Pacific Cruisers - 49ers
I had to change a tire on the Sprinter last week. Same size as the GMC. BUT the Sprinter uses bolts, not studs. It took me 20 minutes of
trail-and-error jacking and shimming to get rim to line up. Mercedes, besides having the brainstorm of using bolts, also decided to make the tolerance
so close you couldn't get the threads to catch unless it was **exact**. I was so frustrated that I considered calling a $$$ truck service to come try
their hand at it but finally got it lined up.
Thanks for the headzup, Matt, I don't need another hernia. I just ordered these
https://www.amazon.com/Goplus-Vehicle-Positioning-Moving-Capacity/dp/B01N5G294Q/
77 Royale Coachmen Side Dry Bath
76 Birchaven Coachmen Side Wet Bath
76 Eleganza
Elizabeth City, NC
> Hmmm.
That actually looks much closer to what I have.
Matt,
Brilliant idea!
I have four of the Pittsburgh Automotive - Item #61917 / Item #62234 Dollies in Houston and four in a crate that will get shipped to
Sydney.
I use them to move the 1995 Jeep Grand Cherokee I got from John Sharpe in my storage facility in Houston. I was using a set of item
#67338 / item #60343.
John and I found that the item #61917 / item #62234 swiveled MUCH easier than the item #67338 / item #60343.
I bought both sets when they were on sale for $69.99 each making a full set $279.96 plus $6.99 ground shipping for a total of
$286.99. Eastwood's are $379.94 plus $93.06 shipping making a total of $472.94 which is almost $200 more.
I would also like to point out that the Harbor Freight units are mechanical, they have a ratchet that engages as you raise the car
whereas the Eastwood units are hydraulic.
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Matt Colie
Sent: Thursday, August 10, 2017 11:27 PM
Subject: [GMCnet] Makes it easy to manage wheels
the bit with both magazines and then wet sheets of PE, but that gets old fast.
Then I had to move something, (if you should see my barn, this would be no surprise) and uncovered the stack of "Gojacks" as they
are trade named. The LED (only recently upgraded) in my brain finally lit. I dragged out one of them and stood the loose wheel in
said to my self, "Hey Stupid - the tire is on a jack." So, I pumped the wheel dolly until the studs were close and with the tire on
the rollers, rotating it to mate it with the studs was simple.
in my barn.
The Germans and their wisdom surrounding the use of wheel bolts isn't totally flawed. On many of the German vehicles, there is usually a long straight rod that you are supposed to insert through the wheel bolt-hole, and the hub bolt-hole, levering the wheel onto the hub. This rod automatically aligns the bolt holes, and holds the wheel in place while you insert a bolt in an adjacent hole.
Depending on the vehicle, this alignment rod could be the jack handle, the wheel bolt wrench handle, or a totally separate item in the tool kit. Reading the owner's manual will usually provide the correct method for wheel removal/ installation, and often explains the use of this tool.
There are also aftermarket installation aids which are basically a 4" long stud with a rounded end. You simply screw it into one of the wheel bolt holes in the hub, glide the wheel onto the stud and bingo, it is aligned and self supporting, ready for you to install the adjacent bolts.
When served lemons, we make lemonade.
Les Burt
Montreal
'75 Eleganza 26'
Thanks for the info, Les. There wasn't a jack, lug wrench, or handle with it when I bought it. I'll check in the floorboard toolbox to see if there's
any sort of alignment rod.
76 Eleganza
Elizabeth City, NC
G'day,
See the TOOLS section of Ragusa http://www.ragusarv.com/
RV-09
Wheel Lifter Bar
This lever bar allows you to lift heavy tires by placing the lifter into the center hole of wheel and over 4" dust cap. Lift wheel
and rotate to locate studs.
$29.00 ea.
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Les Burt
Sent: Saturday, August 12, 2017 2:02 AM
Subject: Re: [GMCnet] Makes it easy to manage wheels
hole.
Les Burt
Montreal
'75 Eleganza 26'
