Main power fusible link
RF_Burns
Super Moderator
Staff member
Sep 7, 2008
5,138
1,333
113
Ontario Canada
The electrical diagram shows a Black #16 fusible link from the "Battery Pickup Junction Block" to the Horn relay bolt terminal.
Mine is a Yellow wire and looks more like a plain old #12 wire... SO I'm thinking the fusible link was replaced with a piece of wire in the past. A
#16 seems a bit small with two #12 wires coming off it. Is #16 still a good choice, or should I goto #14 size link?
Thanks.
Bruce Hislop
ON Canada
Not a real answer, but I experienced the fatigue failure of one end of that
wire as I was high tailing it North on I-75.
Backfire, engine quits, gauges all read zero, no 4 way flashers, nothing
but house power.
Took a bit to puzzle out and crimp a new end on. Replacement is on the
list, so I'll be watching for opinions.
Russ
> Thanks.
> Bruce Hislop
> ON Canada
The primary fusible link is a number 16 ga black. DO NOT go to a larger size! GMC designed safety into their electrical systems. The 16 gauge is the weir size that has a fuse rating. Going bigger just created more smoke!!!
What is a fusible link:
A fusible link acts much like a fuse; only it’s designed to handle a different type of potentially hazardous scenario. These links are actually strands of wire wrapped in a fireproof covering and are thinner (smaller gauge) than the wiring harnesses they’re connected to. They are placed in-line between delicate harnesses and large electrical current sources in your car—between the battery and alternator, for example.
These links must transmit high-current electricity and protect the rest of the electrical system from dangerous spikes that could cause a fire. If there’s a surge, the link actually melts, as its resistance to heat is lower than that of the circuits it’s protecting. This cuts off power while protecting the engine bay from a fire, thanks to its fireproof wrapping.
Unlike a regular fuse they are not instantaneous but heat up before failure.
The NAPA # is BEL 784695 and retails for $4.09 US and you should be able to find it at any good autoparts store in CA.
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
75 GMC Avion (Under Reconstruction)
Michigan
> but house power.
> Russ
>> Thanks.
>> Bruce Hislop
>> ON Canada
>> GMCnet mailing list
