We use to supply the Magnet for the final drive drain plug for the Aluminum
cover that has the drain plug.
Should one have large partical, one is having an issue and it will damage
the unit.
We suggest people to drain it and refil.
We have supplied almost 3,000 final drive units and know of only 3 units
where a gear chipped off and caused a proplem.
We warrentied all and they had over 50-100,000 miles on them.
We have had few where the pion bearings have failed, again we took care of
it n/c .
> Bob, the particles that are going to be a problem in the final drive are
> the size of half a bearing roller or half a ring gear tooth. Preceeded by a
> WHOLE BUNCH OF GNASHING AND GRINDING. The very small particles don't seem
> to get all the way up to the filler plug, choosing instead to remain in the
> nether regions on the final drive case. I have seen several grenaded final
> drives, and it seems to me that they are just fine until they aren't, and
> then you are on the hook. The last one I know about occurred last fall. The
> pinion bearing cage failed as well as the pinion shaft where the pinion
> bearing is pressed on. It howled like a banshee on deceleration, but made
> very little noise on pulling. It got the owner home in one piece. There was
> only junk left inside the case. If I can find the e-pics, I will send you
> some. I am on my cell phone now. So, I question if the magnet in the drain
> plug will have much value. Better to take off the cover and flush the case
> out, the way you have been doing it.
> Salem, Or
> 78 GMC ROYALE 403
> > Have one on my 3.21. Do not think it is needed. It is custom, not
> > store bought.
> > Jon Roche
> > 75 palm beach
> > St. Cloud, MN
