Machining Brake Drums
kmorefield
Member
Jan 4, 2020
62
6
8
I'm working on my brakes - new shoes, springs, cylinders, replacing rubber lines, etc. One of my drums has some pretty good scoring grooves in it.
No telling how that happened. Does anyone have the specs for how much a factory drum can be turned in order to get rid of the grooves. I'd like to
drop it off with the local brake machinist. I just don't know what specs to provide them... Anyone?
Ken
1975 - 26’ Eleganza II
Unsure of what upgrades may have been done. I'm working on sorting that out in the coming months.
Ken Morefield - Redding, CA
Specs are on the drum. 11.09"
On Wed, Jan 13, 2021 at 4:56 PM Ken Morefield via Gmclist <
> Ken
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
Yes all drums have the max allowable internal diameter stamped usually on the edge. Keep in mind as you approach that size, they will fade sooner
(less mass) and warp easier if you drive aggressively.
I found the spec on the inside of the drum
On Wed, Jan 13, 2021 at 5:59 PM John R. Lebetski via Gmclist <
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
And, as I learned on a '39 Olds in '54, the drum can split, leaving you
with no brakes. I was 16 yo when I bought the Olds for $50. My Dad
insisted that we get the brakes & steering up to par before I drove it.
That included having the drums turned at the local machine shop. Almost
the first stop sign my teenage self and best buddy came to, doing probably
'way more than the speed limit, I had to do the teen-stop for the sign and
the city bus on the cross street. When I got on the brakes, nothing
happened before the pedal hit the floorboard. I managed to swerve around
the corner and miss the bus. The curb finally stopped us. The shop had
over-turned the drums, allowing one of them to split all the way around the
circumference and across the freed band.
Needless to say, I've been very careful about turned drums for the past 66+
years!
On Wed, Jan 13, 2021 at 7:59 PM John R. Lebetski via Gmclist <
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Yall can shame me but I never turn discs or drums. Any scoring is concentric anyway, so the puck or shoe quickly takes a set to the grooves.
Anything grooved beyond the machining limit - .0625 or so - needs to be replaced anyway.
I'm with you - I don't think I've ever machined or resurfaced rotors or drums, regardless of the vehicle...
Rob
76 Royale Twin Beds, Dry Bath
Victoria, BC
> --johnny
> Braselton, Ga.
Many, many, NEW BRAKE ROTORS are seriously out of true as well as
concentricity. After they are bolted onto your hubs, they should ALWAYS be
checked with a dial indicator. If their runout is greater than .003" they
should be trued. Unless you just happen to like pulsating pedals and
excessive wear on pads, calipers, and front wheel bearings. Then, slap 'em
together and forget about it.
On Thu, Jan 14, 2021, 3:08 PM Rob via Gmclist
> Rob
> Victoria, BC
> > On Jan 14, 2021, at 2:54 PM, Johnny Bridges via Gmclist <
> replaced anyway.
> > --johnny
> > Braselton, Ga.
> me in hell
And actually, to properly true a disc, it should be trued on the vehicle. Which we used to do with the racer. Takes some 'doing' because you need a
rigid grinder stand and a way to spin the disc.
Thanks all. I did confirm the specs are stamped right on the rotor. Swung by the machine shop and he said the grooves are too deep to get out. He
could clean them up some, but they won’t be perfect. It looks like way back on a former lifetime, a previous owner wore the shoe down to the
rivets. Just the one drum. Maybe it was maladjusted... so leave it as is, buy a new drum, or machine it concentric and run with it...
Ken,
Jim K has replacement drums. I put 4 on years ago. Recommend truing on a brake lathe pilotted on the bearing races after bolting on.
My 2¢,
Rick Staples
G'day,
If you buy brake drums or disks that have been re-drilled to match the eight bolt pattern of the GMC they are probably made in China. Last time I
bought either I got them from Cinnabar and they were not re-drilled they had eight from the manufacturer.
Rob M. (USAussie)
The Pedantic Mechanic
Sydney, Australia
'75 Avion - AUS - The Blue Streak TZE365V100428
'75 Avion - USA - Double Trouble TZE365V100426
+1 bought new drums from applied because on of mine had a deep groove. Did have to get them trued. I did notice they were lighter than the OEM. Is
this a consideration? I put the new, lighter drums on the middle axle (because hey, they're new) and the original heavier drums on the rear. Wondering
now if I should have done that the other way with the old drums with more mass up front due to increased braking work that is done / more heat to be
dissipated
Corey P /
Hilliard, OH /
1974 Glacier 26' /
3.70 FD /
ION Wheels
> need a rigid grinder stand and a way to spin the disc.
> --johnny
Snap on and some others used to make a tool for this...
https://www.ebay.com/itm/snap-on-ya180-kwik-lathe-on-the-car-rotor-lathe-/313314171051
Mark S. '73 Painted Desert,
Manny 1 Ton Front End,
Howell Injection,
Fort Worth, TX
We had something like that at Mac's for the racer, Mac (McCune) fabricated it after looking at what the Honda shop was using.
