The implication in the repairman's statement "...the Macerator like to
have water in it at all times" may have been water or water and
antifreeze. HOH is strong stuff, an engine water jacket is not rugged
enough to withstand freezing. My guess is that the exclusion of air
(ozone and other strong oxidants) by surrounding the impeller with water
and RV antifreeze will slow the hardening (which is most probably
oxidation) process.
> I live in Connecticut, it freezes here in the winter. These pumps are
> rugged enough, or designed, to tolerate freezing? I am planning to
> install a macerator and was trying to figure how to install it in such a
> manner so it would not freeze. I did not know that there was a hardening
> issue with the impeller.
> >From: duane m simmons
> >I live about 10 miles from a Jabsco factory/distribution center & have
> >been there many times for repair of other people's macerator. The
> repair
> >man has stated to me many times that the Macerator likes to have water
> in
> >it at all times & the impeller will not harden as much. So I always
> >leave water in my holding tank (no gate valve between tank & macerator)
> >have never had an impeller harden to the point that it would not start &
> >pump.
"I do whatever my Rice Krispies tell me to..." John said, from inside a
1974 Glacier.
oxidation) process.
> repair
> in
> >pump.
1974 Glacier.
