lug nut torque
ktcnyc
Member
Sep 14, 2020
99
13
8
Dingmans Ferry, Pa. and NYC
Hi folks - I have steel wheels and new 16.5 tires - is it really true that the lug nuts are torqued to 250 lbs. ? I'm having brake work done at a
truck repair shop and I want to give them a heads up.
Thanks.
Kevin Cloutier -'77 Eleganza II-455, 6 disk brakes, Edelbrock carb, headers, , resident of NYC and Dingmans Ferry, Pa.
'72 MGB-GT & '73 MGB convertible
Member GMCMI since 8/20
That IS the spec, although I don't think most people follow it to the letter (or number as it were).
I believe the friction between the shoulder of the nut and the wheel surface has something to do with that high torque spec. I think most people have
found that the Alcoa (different type of lug nut) spec of 140 ft lbs is sufficient. I would suggest that if you DON'T torque to the spec, you should
check the torque after putting on a few hundred miles.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Rather than wheel nut torque, I think breaking the rear shocks is more a problem for a non Gmc familiar shop.
Put rear weight on the bogies with a jack, then let down air pressure in the suspension air bags before full extension.
Raleigh, NC
> Thanks.
Yes Kevin, the number and don't miss it. We carry both the OE lug wrench and a breaker bar and socket for this and a 3' length of pipe to use with
either in the event I have to change a tire. Just for reference, I haven't broken a stud in years and that one was damaged for me before I go the
Chaumière.
Matt - working setup this week
Just have them jack under the bogie boxes for sure. Also, under the lower
control arms, or under the engine front cross member, NOT THE RADIATOR
SUPPORT.
> Raleigh, NC
I have a 1977 SOB motorhome with steel wheels and factory lug nuts. They are flanged nuts made in
one (1) piece so not swivel, like stock GMC MH lug nuts. I still have the factory owners manual.
The specified wheel nut torques is 300 to 350 lbs/ft. Yes I have a great big SNAP ON 3/4 drive
breaker bar and SNAP ON socket to fit. To loosen these takes all 225 lbs of me on the breaker bar
bouncing up and down. You'd better be ready when they come loose with a SNAP. I have a rated
400 lbs/ft air impact gun that will undo them just. So I'm not surprised at the spec for a
GMC MH. REMEMBER DO NOT use the steel wheel torque spec for aluminum wheels will ALCOA style
nuts. JWITIK (Just what I think I know)
DAVE KING
lurker, wannabe
Toronto, Ontario, Canada
No, the lug nuts should be torqued to 140 pounds.
JR Wheeler 78 Royale 73 Painted Desert
Now living in Oregon
> SUPPORT.
> Salem, Oregon
> > Raleigh, NC
