For you speed enthusiasts, here's some SWAG estimates of the power and axle
torque that you'll need to propel a GMC to 120 MPH. (In case there's anybody
that doesn't already know, it's a Scientific Wild As- Guess).
I think it takes about 70 HP to drive the coach at 60 MPH. Part of this is
aerodynamic drag and part is friction (tires, bearings, etc.). If you assume
225R75 16 tires and the stock 3.07 final drive ratio, 70 HP equates to an axle
torque of 267 lbs ft on each axle. If the converter slips at 5% (probably still
a reasonable guess under these conditions- and somewhat verified by Paul Bartz's
measurements of engine speed vs. MPH, which he kindly shared with me), the
engine speed would be 2225 RPM.
Extending those same assumptions out to 90 MPH, gives a required driving power
of 189 HP, axle torque of 482 lbs ft per axle and an engine speed of 3428 RPM
(assuming 7.5% converted slip).
Taking it out to 120 MPH gives a power requirement of 410 HP, axle torque of 782
lbs ft each and an engine speed of 4598 RPM (assuming a 10% converter slip).
I'll not bore the Net Gang with the details, but if anyone is interested in the
calculations, I'll be glad to share them (maybe direct is better).
Clark Searle
78 Kingsley
Mt. Pleasant, MI
Clark Searle
78 Kingsley
Mt. Pleasant, MI
