Gene,
To do the 120 MPH with a stock engine we should be ok with a stock 3.07 or
just slightly larger tires. The Olds faq says the motors are good to 5000
RPM stock, so we could push it up to 4500-4700 without too much worry.
This should be enough for 120. If we go with a motor designed for high
RPM, however, we could use the high ratio final drive and the trans
sprockets and should still have a couple of RPM to spare.
Zak
>-- [ From: Eugene Fisher * EMC.Ver #2.5.3 ] --
> Has any one calculated the rpm required for 120 mph??
>My coach ( with mod ratio xmission) is 2700 RPM at 60 MPH.
>I think I would have a hard time reaching 5700 RPM at 120 MPH.
>gene
>Gene 76Palm Beach /Or/CA
>GMC Technical Information
>http://www.california.com/~eagle/
Zak
>gene
