> The gauge on our 78 Royale hasn't functioned since I got everything back together. Didn't check for function prior to disassembly. Short version.
> Too much mouse shit to deal with. Wirings checked, and now in a conduit. So what ohms readings should I look for?
> Bob Dunahugh
> 78 Royale.
While this might not apply to your situation, since you have a Royale, my LP gauge never really worked for the first 17 or so years that I had my Palm
Beach. The gauge on the tank and the reading on my monitor panel always matched, but the readings had no real correlation to what was in the tank.
Once I switched out the tank sender with a known good one someone gave me, still the same. I had always suspected that the sender in the tank was
messed up. I was going to use a "GMC Round To-it" someday to remove the tank and have someone open it up and fix or replace the sender. Fortunately,
I never got around to doing that job.
About a year ago, while I was fooling around with something unrelated in the LP gas compartment, I happened to notice that the external sender did not
look like it was completely seated in the recess on the tank. It looked to be about 1/16" off of being all the way in. It had always looked OK to my
untrained eye, but that day I thought about the fact the sender inside the tank and the one outside the tank are magnetically coupled and that perhaps
too big of a gap could cause problems. To make it fit better I decided to sand down the circumference of the sender (I had a spare so I was not
worried about messing it up) just enough to get it seated all the way. As soon as I pushed it in and hooked up the wires the reading on the gauge went
to showing ~80% full (I had just had the tank filled) from the close to empty that had been showing before. For the past year, the gauges
consistently match pretty closely to what is actually in the tank.
To think that I went over 17 years without a functioning LP gauge when all along the problem was that the senders on the tank were never seated
properly because they were slightly too big around to fit in the tank. It's a good thing I never went to the trouble of taking the tank out and having
the internal sender "fixed" or replaced. That sure would have been a waste of time and money.
Richard
SE Michigan
www.PalmBeachGMC.com
Coop Roller Cam 455, Howell TBI + EBL, 3.42 FD, Quadra Bag, Macerator, Manny Tranny etc.
