Amen Arch. If everyone will listen to you and Emery there will be no more
incidents with propane.
Bob McLaughlin
- -----Original Message-----
[mailto
wner-gmcmotorhome]On Behalf Of Gcbr
Sent: Sunday, May 28, 2000 11:03 PM
To: gmcmotorhome
Subject: Re: GMC: LP Gas Cylinders
In a message dated 05/28/2000 2:08:02 AM Central Daylight Time,
> two weeks ago a 500gal tank exploded at Bay Gas while
> the attendant was filling a small tank...Two employees
> critical...makes you think twice when you see these
> guys filling the tank.....like time for a long walk while they do it!!!!
Rob
If it was the 500 gal tank that exploded then it was some sort if freak
accident. I have lived on my farm for 30 years. It is all powered by
propane.
I have seen many posts here that almost seem like people just dont
understand this gas. Propane is heaver than air. Design for it. If you have
a propane reefer make sure there is a way for the propane to get out. A vent
hole into the wheel well is easy to do. This is important because since
the reefer is in a sealed compartment you will not smell it inside, nor will
your propane detector mounted inside the coach. Without a lower vent
it could build up the point of a problem.
Inside the coach you are going to smell the problem long before the propane
builds up enough to cause a problem. Even if your smeller is not as good as
it used to be you will notice it. If you still have some fear then put in a
propane
detector. Mount it on the floor between the stove and furnace. Now if you
want
first rate protection cut out the wall behind the detector so it can have a
chance
at sniffing it before it builds up enough to spill out of the cabinet. Think
heavy.
Propane is heavy---most people think of gas as rising---propane will never
be
used in balloons.
Propane fires are nothing like natural gas fires. You hear about big natural
gas explosions. Propane seldom does that. An exploding 500 gal tank to me
says there was a bad pump in the system. In the 30 years here on my farm
with 7 rental units I have had 2 propane fires. One the people stored their
weights next to the hot water heater. They fell over and cracked the gas
line. It built up enough in the closet to catch fire. It was just a flash
over
fire. The carpet was singed and the paneling darkened up about 4 inches.
The other fire was a different cause same results. Neither resulted in any
real damage. Propane does not explode like natural gas. If you have ever
put gasoline on something you wanted to burn----then when you tried to
light it there was a carpet of fire on the ground---thats a propane fire or
explosion if you like. I do know of one house that exploded from a propane
leak. The people stated that the ceiling fan was running when they left.
Yes,
that was the kind of boom you get from natural gas--heard it here about
2 miles away.
Just some thoughts. Emery is right about have a whacker on hand to
fix stuck valves. Here on the farm I use a brass hammer. The one thing
I would add is if a valve sticks 2 times change it out. It will stick again.
I dont care if it is a new one or old one 2 times and it is gone. I dont
know what makes them stick but I do know that if it starts sticking
it will do it again. When on the road I do not fill up at an RV park or some
one horse store. I try to get to a propane company. I know
that my be hard for some of you but gosh I hate those places. I admit
in all my years of camping I have only filled 2 times on the road. The
rest of the time my local propane company does it. Dont fill on a still
day---the stuff hangs around---fill when the air is moving. Much less
chance of a problem. Hope I did not bore you all to death.
Take Care
Arch
