It was touched on, but not discussed... if the steering box is set at the high point, and the steering wheel is straight ahead and the clamp bolts are
positioned as they should be but the cv joint bolt holes do not line up, how does one adjust it? My coach wasn't right when I got it, and I am trying
to get it right. How and what do I index so that it is right? As it is right now, the cv joint screw holes are off about 30 degrees. Anyone? Thank
you!
you!
