I’ve been running the Burgeson steering now for 2 seasons and it performs perfectly, just like it has on all the other car projects I’ve built. Easy to put together the pieces and probably a third of the GMC cost.
1977 Kingsley (Elvis)
403 - Mostly Stock
Calgary, Alberta, Canada
> After about 8000 miles with the Borgeson set up I have nothing but good things to say about it. Took me about 30 minutes to cut the shaft, as per
> instructions on the Borgeson site, (important), and assemble the unit on the bench, and about another 30 minutes to center the system and install. The
> toughest part of the job was removing the old unit!
> The ease of accurately centering the steering system has to be one of the advantages of this system as well as no ongoing lubrication requirements.
> Although the D shaft is pre-lubed and has a seal on the sliding part,I did plug the exposed top of the D shaft with silicone to prevent water running
> down the inside of the shaft.
> Norm.
