lower steering shaft complete new replacement
kab7
1,230
2
38
San Jose, CA
> I used Borgeson parts through out. I used Borgeson # 154943 for the 3/4 DD x 1" 48 that incorporates a vibration damper, the other 1" DD x
> 13/16-36 (115240) and a telescoping steering shaft (450024).
> Hal
Hey Hal, just revisiting this idea. You've had your Borgeson setup for a year or more. How do you like it?
thanks,
Karen
1975 26'
Karen et al,
Alex Ferrara has developed a procedure to rebuild the OEM units.
You can contact him on:
Cell: 386-986-8886
Email: lmeyer7436
USAussie - Downunder
thanks,
Karen
Karen, all seems good with the parts. Have a little more than 5000 miles on them and steering is fine with no adverse effects.😀 Hal .
1977 Royale 101348,
1974 Eagle Bus 45',w/slideout
Thanks Hal, that's terrific. I'm sick of trying to make the old floppy greasy heavy monstrosity work,
and no matter how hard I try, I can't get the lower pinch bolt to really grip. Even tried changing
the steering box recently hoping it would help but it made zero difference. I'm pretty sure now the
remaining sloppiness is in the intermediate shaft, and I'm done messing with it.
thanks,
Karen
1975 26' expensive patience tester
Karen,
I'll buy your OEM lower steering shaft assembly and CV joint; how much do you want for it?
thanks,
Karen
> Karen,
I'll wait to see how we like the borgeson solution before getting rid of the old one.
You'll probably have offers from other folks who have spare intermediate shafts lying around before then.
thanks,
Karen
1975 26'
Okie Dokie!
thanks,
Karen
