Gene I would have a problem with your statement to drill out the holes for
larger bolts. That would involve also drilling the holes in the balljoint
and may weaken them and that would not be wise. The bolts that come with
the ball joints are strucuturally strong enough if the old rivets are
drilled out correctly. At least that is my experience. Use the appropriate
thread locker on the bolts and save yourself a lot of frustration.
>-- [ From: Eugene Fisher * EMC.Ver #2.5.3 ] --
>While I was traveling around, I visited two GMC shops to ask questions.
>I got the following about lower control arms.
>Upper ball joints seldom need replacing
>Don't replace ball joints unless you really have to
>Only the arms with replaced ball joints crack
>The bolts that replace the rivets get loose and ball joint moves
>Tighten the bolts all the time
>The bolts that come with replacement ball joints are too small -- drill
>out to larger bolts
>Shops replace arms with reinforced toronado arms
>Reinforcing varies from "just what GMC did" to parts all over the place
>Arms usually fail in parking lot making a tight turn--lots of side
>pressure on arm
>Some people are getting by with welded repairs to the arms
>gene
>Gene 76Palm Beach /Or/CA
>GMC Technical Information http://www.california.com/~eagle/
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
>out to larger bolts
>pressure on arm
>gene
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
