Just had both lower control arms tanked and inspected. No cracks. 115K
miles.
Gary
'77 Kingsley
North Bend, Oregon Coast
> -- [ From: Eugene Fisher * EMC.Ver #2.5.3 ] --
> Now I am worried again.
> Article in MHMP by the grand old man Bob Blekinsop about failures of
> lower control arms at the ball joint hole. He recommends checking when
> doing bearings and lower ball joints.
> Local GMC er just checked and one of his was cracked
> Just followed thread that said a lot of the ball joint replacements
> using bolts were done badly. There is some indication that these
> failures might be caused by bad ball joint replacement.
> This looks like an indication that maintenance / poor maintenance might
> be the root of this problem ? Does this mean that if we see bolts on
> our lower ball joints we better be worried??
> Lower control arms are not in great supply, so is a good idea to get a
> handle on this problem.
> I would be interested in hearing from folks doing bearing jobs as to how
> many find this problem and maybe the following info:
> how many miles on rig
> bolted ball joints?
> original control arms?
> how found the problem?
> can be repaired by welding?
> any other info?
> scared straight ---gene
> Gene 76Palm Beach /Or/CA
> GMC Technical Information
> http://www.california.com/~eagle/
miles.
Gary
'77 Kingsley
> bolted ball joints?
> any other info?
