Low power transfer switch
Keith V
3,582
377
83
So i have a 400 watt inverter that i use to run my EBL WUD and supply USB power in the cab. The inverter powers a duplex socket that also has usb power.
Id like a low power automatic transfer switch to switch from the inverter to shire power when available.
I only need 400 watts max.
Has anyone seen or built such a beast?
Dont see anything on fleabay or Amazom...
It seems like a 110v DPDT relay is all thats really needed
> power.
Keith,
You don't even need that if that inverter is off the house bank. Just leave it on. If you are using power from the inverter, the converter will just
work a tiny bit harder.
Besides, if you have a transfer contactor, when it cycles it will "blink" the 120V available and how much of a problem will that cause??
If it isn't on the house bank, buy a tiny converter charger to put on the main engine start battery - One less thing to worry about.
Keith,
Here's exactly what you asked for. I used a 30 A relay to carry the entire
coach load, for your purpose, you could use a smaller/cheaper one.
http://www.gmcmhphotos.com/photos/g3484-automatic-120-vac-power-source-selection.html
> power.
Thanks Ken, thats what i was thinking. It seemed too simple, made me suspicious!
But i think Matt has the best idea. I do have a nice PD converter to charge the house battery. Why make it more complicated than necessary.
Wait.. did I say that? Lol
Sent: Saturday, April 17, 2021 3:38:44 PM
To: GMC Mail List
Subject: [GMCnet] Re: Low power transfer switch
Keith,
> power.
I agree with Matt and you -- keep it simple. But since I knew the details
of what you asked for, felt I should pass it on. :-)
> suspicious!
> From: Ken Henderson
> To: GMC Mail List
> Keith,
> Ken H.
> > power.
