Hello all, I'm new to the forum here. Just stumbled across this site while trying to search and find any information I can about the EBL Flash ecm. don't know if this is the right place to post since this isn't for a motor home. It's for an older 1968 Chevy C10 with a 250 straight 6 and 3 speed manual trans.
My son just bought it last week and we have been trying to figure out the EBL tune on it. it's tune is based off from a 4.3 v6 but it's running rich. I have been trying to learn as much as I can about the EBL by reading online and finding the original website though the wayback machine.
I stumbled here and found @RF_Burns posted the last update (Thank you for that) and see there is a possibility of continued support and production through Xfire Performance. This is great news! I really appreciate all the work that went into this and keeping it alive.
My first question is, would it be ok by the admins along with others here to seek help here since this isn't a motor home?
Since I found the V2.7 update I was also wondering if the system I have will be able to use the update posted. I believe this is the EBL Flash not a Flash 2. it uses what looks like an old telephone cable connected to an adapter which converts it to a USB for the laptop. I have not found any numbers on the ECM which is painted black and looks like it came as a complete kit from DynamicEFI rather than a DIY setup.
As for the engine running rich. otherwise it runs good. no timing issues that I can tell. If I disconnect one of the two injectors in the TBI the engine will straighten up and run almost perfect. Maybe a little too lean for any acceleration. I connected a fuel pressure test guage to the pressure line and getting a steady 18 PSI. iirc pressure should be around 11 or so for TBI. So what I tried is taking my pliers and pinching the hose on my test gauge T on the supply side allowing the pressure to drop down to about 10 PSI restricting some of the fuel. as soon as I did this with both injectors connected, it straightened up and ran good, though I was not able to move the throttle while holding my pliers.
The truck has sat for several years long enough for the fuel in the tank to go stale along with the fuel pump to go south. the previous owner cleaned all this out and replaced the fuel pump before my son bought it. My first thought is possibly the pressure regulator and or injectors have some gummy old fuel or varnish stuck inside. I ordered a GM TBI rebuild kit for it and plan to do that this weekend.
In hopes of this fixing the fuel pressure and any chance of varnish in the TBI, I was using the EBL utility to calculate the BPC for the engine just to verify what is in the bin file on the ECM. when I loaded the bin I extracted from the ECM (using EBL_v31.xdf supplied by the PO) the BPC vs VAC table is set to 181 across the board. using the utility calculator entering 250ci with 45 #/hr injectors that are factory for a 4.3l (verified the injectors in the TBI) with a 11 psi fuel pressure I get 191, with 18 psi I get 150. the base tune bin for a 4.3 has 181 same as what is set in the bin which is loaded on the ECM.
I feel like this might be were the issue is for the running too rich condition. When I say running rich, when you start the engine cold (60 degrees outside) it runs rough and blows black soot from the tail pipe acting like it's running full choke. as it warms up it gets better but still acts as if it's running half choked.
I don't see any malfunction indicators on the whatsup app and all data from the sensors seem like all of the electronics are fine.
I'm hoping others here have some experience with the EBL and have some advice on where I should be looking or starting becides making sure the throttle body is clean and fuel pressure is correct.
