Hi folks,
I'm getting ready for my AV10 engine monitor.
I'd like to avoid an oil tree of pipe, i.e. adding on to the oil pressure
sender at the front of the engine. Are there any other points where I can
tap into oil pressure and water temp?
Oil temp for the AV10 will be via a probe in a 1/8 pipe tee so what I'm
hoping to find is a spot where there may be a plug that can be replaced
with a pipe to which I'd connect the tee for both oil pressure and oil temp.
I'd also like to find another place to put a water temp probe. I currently
have 2 in use which are the 2 on the forward top of the engine.
As always, I'm trying to not replace "original" but rather add/enhance.
What corner of the engine did I miss looking at?
Heinz
'76 Transmode (455)
Heinz
'76 Transmode (455)
