Re-Lube the gear rack guide for the pin that locks the wheel. You may be able to do it with some pressurized spray lube (like X-Treme or similar that
expands after it comes out of the can) with just taking the steering wheel off. Worth a shot anyways...otherwise you'll have to take the whole deal
apart, which requires certain tools, clean it all up and regrease the moving parts, and there is a trick to getting it back together correctly that is
not apparent when you take it apart unless you watch VERY carefully.
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
