A lot of you that have had problems with blown or leaking exhaust
manifold gaskets might find that you no longer have the little locks
that GM originally put on your engine manifold. This is part number
399423. It is a small metal plate that goes under the two outside
bolts on each end of the manifold (there is not one for the center
bolt). After the bolts are torqued there are small tabs that are
bent against the flat of the bolt head and it keeps the bolts from
loosening when the manifold expands and shrinks when getting hot and
cold.
I would suggest that you torque the bolts to specs, drive about 500
miles and then retorque them and then set the locking tabs. I
suspect this will cure a lot of leakage problems for many of you.
The original part number is still good and any GMC/Olds/Caddy/Chev GM
dealer can order them for you if they don't have them in stock. My
local Olds dealer got them in two days for me from the Denver parts
warehouse with no shipping charge.
You will need four of that part number.
Emery Stora
77 Kingsley
Santa Fe, NM
cold.
Emery Stora
77 Kingsley
Santa Fe, NM
