> > Ok, bingo, LED light work now, thanks guys. Have taken down kithen light and discovered 3rd wire, appears to be white, that is capped off.
> > What was it for? Have notice sometimes that light dims at times when in use.
> The wiring diagram seems to show the kitchen light plus wire to the light is dark blue and the plus lead on the fixture is black (those two should
> be connected). The fixture minus (ground) lead is white, but the drawing doesn't show the color of that wire from the fixture minus lead to the body
> (ground). A couple of other accessories have the white (minus) wire of the fixture lead connected to a black wire that goes to the body (ground).
> You need to measure some voltages and continuities to figure out what is going on. Do you know how to do that?
> I am looking at the wiring diagram here
http://www.bdub.net/wirediagrams/12vdc-ZEO6582.pdf
Never mind. I should have been looking at
http://www.bdub.net/wirediagrams/12vdc-ZEO6581.pdf
Shows three wires at the galley light fixture. One (dark blue)goes to the house fuse block no 1 position, one (brown) goes to the galley light switch
and one (black) goes to ground. I don't know why one fixture black wire is hot all the time from the dark blue wire and the other black wire goes to
the switch. Also, seems like it wouldn't work at all with the white wire floating. Seems a PO has mucked with the wiring. I would need to do some
continuity and impedance checking on the fixture to figure out how it is supposed to work.
73 23' Sequoia 4 Sale
Upper Alabama
