Since were a Onan dealer, they teach us to run the generator for 20 min.
every other month.
> Don't get me wrong, I'm fairly happy with the honda. It is only 2 pole so
> weighs 216 lbs vs over 400 for the Onan. I was shocked that it was so loud
> being water cooled and all. It has two fans, One on the radiator and one
> on the end of the engine like a lawnmower engine. That fan blows air through
> a heat shield which encloses the exhaust to cool it. Kinda cool. Probably
> a safety feature. I built the door on the compartment to honda's specs which
> draws the air across the carb and fuel pump to cool them.
> The lower weight helps since I have it in the same place the GMC had it,
> behind the rear axles. BUT. You have to run the honda at least every 3-4
> weeks or the carb clogs up from the crappy fuel. The Carb is the only
> thing you CANNOT work on without pulling the genset out. Had I known this,
> I
> would have designed a sealed door on the top of the compartment when I
> fabbed it. May still do that If I pull it again for any reason.
> I have a calendar reminder to check the battery level and run the genny
> every 3 weeks... Probably not a bad idea for any Genset.
> -Chr$: Perpetual SmartAss
> Scottsdale, AZ
> 77 Ex-Kingsley 455 SOLD!
> 2010 Nomad 24 Ft TT 390W PV W/MPPT, EV4010 and custom cargo door.
> Photosite: Chrisc GMC:"It has Begun" TT: "The Other Woman"
Applied/GMC, Fremont,CA
every other month.
> I
> Scottsdale, AZ
