Li batteries
slc
261
I am a fan of the Lithium batteries but they need some care in cold weather.
You cannot let them freeze so they need a space inside the coach if you travel in winter weather.
If the battery freezes, it wont charge because of the circuitry for protection.
I dont remember the specifics, but if the protective circuit fails and forces power
to a frozen Lithium battery, it will heat up and can catch fire.
As you know, a lithium battery fire is almost unstoppable. you cant use water to put
a lithium battery fire out. You almost have to have an extinguishment for metal to
put it out and it will be a battle even then.
It is recommended to remove the battery when the coach is stored for winter, and keep
the battery in a warm place in the house. I am not sure why they suggest this as if it
is not charging, the battery should be safe. but you have to disconnect the solar panels.
the power increase from a lead acid is about 75%, not 100%.
The sites I have looked at state that the lithium battery does not like being charged to 100%
and you should not discharge it to its lowest point. This will cut away from the batteries
life span. We see this in the electric car batteries.
Im not going to say not to try lithium batteries but you need to be aware that to be
safe you need to take care of them, especially for storage in cold weather.
And be aware of what to do if your lithium batteries catch on fire.
GatsbysCruise. \
I was so much interested in installing lithium batteries. It came to the point in my construction where I had to make the purchase and I had to settle
for AGM batteries due to the cold temp operation problem. They will get better and cheaper down the road. until then I have to ride with AGM as I am
not convinced of the heated battery box at this time.
Tom & Oki Katzenberger,
Kingsville, Maryland,
1977 23' Birchaven, 455 C.I.D.
LiFePO4 (LFP) batteries cannot be charged below freezing, but they can be discharged and stored. They do live longer at temperatures at temperatures
from about 10 to 45C. I installed my LFP batteries in the clothes closet so they are right beside the electrical cabinet where my charger/inverter
lives. This reduces the length of wire from the charger to the batteries for minimal voltage drop.
There are LFP batteries rated for charging in freezing temperatures. The Battery Management System (BMS) of these batteries will use the available
charging current to warm the battery with an internal heating element to above freezing before applying the charge current to the battery cells.
LFP batteries live longer when stored with only a partial charge. So charge (or discharge) your LFP battery to about 60% then bring it into your
house for the winter. Do NOT recharge over the winter! The self discharge rate is very low on LFP batteries at about 5%, so even after storing for 6
months you will still have about 30% state of charge.
You cannot permanently parallel batteries of different types, but you can temporarily connect them... That is what the BIM charge controller is doing.
A BIM connects the house and chassis batteries together for 15 minutes, then disconnects for 20 minutes to allow the alternator to cool. Since LFP
batteries are not designed for extremely high currents (this is more the BMS maximum current rating rather than the cells) I would suggest to press
and hold the Boost switch for several minutes to allow the chassis battery to recharge a bit from the LFP house battery, then try starting. This will
reduce the maximum current being drawn from the LFP house battery by the starter.
Again, this is a very good article on LiFePO4 batteries:
https://marinehowto.com/lifepo4-batteries-on-boats/
Bruce Hislop
ON Canada
