Leveling system problem
jerry & meri
59
The problem with my leveling system is that the compressor won't shut off at
120# like it used to.
Is this a matter of replacing the pressure switch or what is the trouble
shooting procedure?
Thanks, Jerry & Meri
'74 CL
>shut off at
>shooting procedure?
>'74 CL
Does it shut off at all? It could be an adjustment on the switch or
a bad switch. You should be able to pull the cover off the switch
and see the adjustment screws. If you need some instructions for
adjustment let me know.
If you have to replace the switch the original one is the same as one
used on shallow well water pumps and can be found at many Home Depot
type stores or Farm stores.
Emery Stora
77 Kingsley
Santa Fe, NM
Thanks alot for the info. Emory! I'm headed out the door now to the
local feed store.
You have a great web site and I visit often.
Keep up the good work.
Jerry & Meri
74 "CL
