Leveler leak down
Mar 25, 2020
108
16
I have overhauled the rotary valves and there is no leak down at that end.
And my tank pressure drops rapidly with the valves in hold. So with the
valves shut off, and the bags shut off, and the one way valve new and
working so it is not going out the AC, the tank pressure is going out the
levelers or at least to the line to the levelers. There is also a chance I
have a leak in that line but I don't think so.
That leads me to the leveler itself ??? I'm wondering do I take the arm
loose and 'exercise' it? Take it off and clean it up? Anyone take that thing
apart?
TFHIA.
Dean Hanson
75 Avion with mono bag and shut offs.
Maybe you can free up the valve, worth a shot. I would think a soap test would prove that therory.
Note also that some air lines are very brittle, you could have a crack in one
Sent: Tuesday, April 13, 2021 10:54:29 AM
Subject: [GMCnet] Leveler leak down
apart?
TFHIA.
Dean Hanson
Dean,
We have found that the original Rotary Valves tend to develop a
crevis which will leak.
Lot of people have purchased the Brass Valve kit and love it.
> thing
> apart?
> TFHIA.
> Dean Hanson
http://www.gmcrvparts.com
Dean,
I had a system that remained leak free for a long time. I found two issue and only have a cure for one.
First and fixed was the body gasket of the rotary valves is cork. In the GM labeled rebuild kits that came in my coach, they were cork, but with an
adhesive coating on one side only. After an extended time assembled (several years) they developed a leak at the body joint. This was a level of
leak that we in the sealing biz called champagne bubbles. These can be in range of CCs/hr. (Not a lot, but a leak over days/weeks). The adhesive
coated cork just sealed one face so the other could leak and also guaranteed that the valve could not be disassembled without damaging these gaskets.
This level of leakage is a known issue with composite cork/rubber materials.
When I got kits from Applied, those contained similar gaskets without the coating. When these started to leak (again with the tiny bubbles), I coated
the gaskets with Loctite 565 or 567 (one of those), and the bubbles stopped. Months later, they still don't blow bubbles. Small problem, that stuff
is expensive.
I now have another problem. I know where it is. The ride-height control valves both leak when at the set point. I don't know what part leaks, but
they can be shown to be venting while stationary. You know that they have system air pressure on them at all times - right? The thoughtful PO left
me with a non-identical replacement, but only one. I have not even bothered to pursue installing it. Dave Lenzi used to rebuild them, but he came up
short on some essential component a while back and has better things to do.
So, when I am going to go someplace with the coach, I either set the switch to ACC before I start the walk around or drag a shop air line out to the
tank.
Yes, it is a little annoying, but I have a long list of annoying things that I let go by.
Those leveling valves that Dave use to rebuild are available new and made by a company out of Ohio. I got one rebuilt from Dave and one new one from
Jim K. Both have lasted equally well. Call Jim K. at Applied GMC. He has them, or at least use to have them.
system air pressure on them at all times - right? The thoughtful PO left me
Dean responds:
I believe this is my problem and yes, I know they have air pressure at all
times. And it drains my tank within 2 to 3 minutes. My go around is to use
my Ryobi battery powered AC to set my height with my shutoff valves closed.
Works like a champ. Never use the rotary valves up front, always set to
hold.
Does anyone have "working" ride-height control valves available?
Dean Hanson
75 Avion
73 Painted Desert.
