Leigh Harrison Brake Rotor
Thanks for all of your responses, warm welcomes and participation in this amazing resource. Leigh Harrison brake service quickly evolved into a
caliper replacement. With the calipers removed, it seemed foolish not to pull the hubs and visually inspect grease and bearing condition. Grease was
good, but pitting on one bearing race and not knowing bearing age/service history led me to baseline both driver and passenger hubs with new Timken
inner & outer bearings and races. I documented the outcome and parts used in photos here:
http://www.gmcmhphotos.com/photos/g7122-leigh-harrison-rear-brake-maintenance.html
Advice from older forum entries related to power bleeding the brakes led me to purchase a $71 kit from Motive. A virtually identical setup can be
obtained from Jim Hupy: http://www.bdub.net/jhupy/. The power bleed approach strikes me as a no-brainer considering the alternative (enlisting my
significant other for pedal pumping duty). Some other benefits I gleaned from prior forum entries on the subject:
1. Avoidance of potential master brake cylinder seal damage from extending the master cylinder beyond its normal travel.
2. Ability to perform the entire task with one person and with certainty that old fluid and air are expelled.
Thank you all again for your input and support.
Wackster - 1976 23' Crestmont
Baltimore, Maryland
James,
You may be disappointed with the Motive brake bleeder as the adapter that goes on the M/C is made of plastic and from photos it
appears the fluid feed tube goes through the top of that adapter. I don't believe there is enough space above the M/C for that tube
in the vertical position. You may be able to put a 90 degree fitting in there; however, my experience with those plastic adapters is
not good; they leak.
Jim's adapter is made of THICK aluminum plate and doesn't leak. He has made a change in the kit, he no longer uses chains; he uses
cable now. I have one of his kits in Houston and one in Sydney and they work GREAT!
The Pedantic Mechanic
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of James Wack
Sent: Saturday, December 2, 2017 10:06 AM
Subject: Re: [GMCnet] Leigh Harrison Brake Rotor
evolved into a
with new Timken
Baltimore, Maryland
Rob,
So far so good with the Motive adapter (https://www.motiveproducts.com/collections/adapters/products/1105-rectangular-early-american-adapter). It is
a solid AL plate with a thicker section down the middle that is drilled and tapped to provide the fluid path for the forward and rear reservoirs.
That said, I imagine Jim Hupy's cables would definitely be an improvement over the chains. I got it all to work, but getting even tension on the
hold-down's was awkward. Of course it doesn't help that my PO installed "Brake-Guards" that interfere with the hold-down arrangement of either
product. I intend to try making my own adapter from an aftermarket replacement master cylinder cover. It would be so much easier to snap the bales
over a stock cover with inlet ports for pressure bleeding than fuss with the AL adapter and hold downs.
Baltimore, Maryland
James,
I had never seen the metal flat plate before the ones I saw all had plastic flat plates that leaked.
You could make your own cables from parts available locally.
We have discussed those "Brake-Guards" here on a number occasions and the conclusion has been SNAKE OIL.
Sydney, Australia
Sent: Sunday, December 3, 2017 7:37 PM
Rob,
(https://www.motiveproducts.com/collections/adapters/products/1105-rectangular-early-american-adapter). It is a solid AL plate with
tension on the hold-down's was awkward. Of course it doesn't help that my PO installed "Brake-Guards" that interfere with the
hold-down arrangement of either product. I intend to try making my own adapter from an aftermarket replacement master cylinder
Baltimore, Maryland
Rob,
Miguel at MGM GMC looked the coach over before I attempted the drive to Maryland. He had a similar opinion regarding the Brake Guards - worse
actually, he thought they may result in a fractionally increased brake response time. They will come off, maybe this maintenance cycle. As far as
the cables - yes, I have access to a swaging tool and will make some up. I would have finished up the bleeding this afternoon but was a little
shortsighted and only purchased 1 qt of DOT 4 brake fluid. Not sure what the community thinks about DOT 3 vs. 4, but I was committed to the better
rating considering all the other time and expense I put into the effort.
Baltimore, Maryland
Why do you feel that DOT 4 is the better rating?
There are differences besides boiling point such as viscosity and anti corrosion.
Problem is that under certain circumstances DOT-4 doesn't last as long; it absorbs moisture faster than DOT-3 and will sometimes have a lower boiling point in 6-months. So count on replacing DOT-4 fluid that often to keep it "better" than DOT-3.
Do not assume that DOT 4 will necessarily be better for your system than DOT 3. There is a reason that DOT 3 is specified for a number of cars. For one the compatibility of the specific rubber types used for components chosen to be in that car's system has been tested using DOT 3 by the braking engineers. Since I keep my vehicles a very long time I would want to know more about whether putting in DOT 4 is the best for a particular system.
There are reasons that DOT 3 is still on the market. If the Department of Transportation felt DOT 4 were “better” why would they still allow DOT 3 to be sold.?
It is not simple to just say one is better. Depending on conditions of use and the system it is in there are times when one could say that DOT 3 is “better”..
Frederick, CO
> Rob,
> Baltimore, Maryland
James,
After researching the various brands of brake fluid here's what I use:
http://www.gmcmhphotos.com/photos/aa-miscellaneous-photos/p41972-ate-brake-fluid.html
Sydney, Australia
Sent: Sunday, December 3, 2017 9:48 PM
Rob,
Guards - worse actually, he thought they may result in a fractionally increased brake response time. They will come off, maybe this
maintenance cycle. As far as the cables - yes, I have access to a swaging tool and will make some up. I would have finished up the
committed to the better rating considering all the other time and expense I put into the effort.
Baltimore, Maryland
Thanks Rob,
I had seen this product in conjunction with various YouTube video on power bleeding. I thought the concept of alternating colored fluid was quite
clever and am somewhat surprised that colored brake fluid seems unique to the ATE product line. Guess I'll add 2 quarts of (unopened) brake fluid to
my growing list of shelf-stock for GMC maintenance. Might need more shelves.
Baltimore, Maryland
James,
As noted on the Photo Site the Blue fluid is no longer available.
Sydney, Australia
Sent: Tuesday, December 5, 2017 11:12 AM
Thanks Rob,
fluid was quite
Baltimore, Maryland
