> Good Morning America,
> anyone ever made some tests to determine how much of a 80amp or 100amp alternator ended up in the house battery on an average day of driving?
> Looking at more recent RVs I see alternators exceeding 200amp, and I wonder if todays cars need more amps, or if they are just able to provide
> more charging.
> Inquisitive mind wants to know
Thanks a bunch.
> Best regards
> Peer Oliver Schmidt
> PGP Key ID: 0x83E1C2EA
> '76a Eleganza II, VA
Peer,
I might be a a better position to answer this than most.
My 73 coach has an 80amp model alternator. If we have dry camped for a couple days and I crank up the main engine, and it comes up to 1300, the
instrument reports about 80 amps for a short time. I do not have any monitor except voltage on the starting battery, but at that same time, it will
show a terminal of about 13.8. Guessing from the charge curves, that terminal would be a charge rate around 20amps. This is what I would expect to
see after just cranking the main engine to start. That usually takes about 8 or 10 compressions to fire. If you are not aware, 23s have the house
bank in the front and mine is a pair of GC2s. I believe this is why I had trouble with the alternator belt. I know from boat work that 100amps on a
12V (13~15V) system is where any single V-belt runs out of sense of humor. I can also tell you that it will take about 4 hours of driving to get the
monitor to say that the house bank is at 90%. The house bank is will have been being charged at 14.8 that whole time. I would like to get this down,
but that just is not easy to do. Programable voltage regulators are available, but for me, the cost/benefit ratio just is not there.
Why do new cars have 200amp alternators?
Because passcars now have outrageous electrical demand. Think about the heated stuff: Not just back windows and mirrors now. There are also seats
and steering wheels. Then, think about the power that is now used by the engine controls. I almost didn't mention the other stuff.....
Then, when testing a new platform, we were often told to move the vehicle at lease 4 times a day and never more than one half mile. It takes about a
week of that to screw things up.
Did you notice the bundle of wires in those new alternators? They go to the ECU. The alternator is off-line for a short time after a cold start and
the ECU eases it back in slowly and manages the idle while it does. If it just threw the load back on the cold engine it will stall it. I can
actually have that problem if I am not careful with the after dry camp cold start. I can survive if I can get the engine idle speed low enough to
stop charging.
I bet I opened another question. If so, I'm here.
