> Does anyone have a good handle and a procedure to re-install the left side drive
> axle with the new super boot ?
> I seem to having trouble getting the shaft back into the knuckle.
> Sam
Sam,
I don't know if its the same for the left, but I recently found that by lowering the
coach a few inches so that the wheel is touching the ground and starts to raise the
control arms, there was less angle in the outer CV joint and the axle (drive shaft)
slipped into the knuckle / hub much easier. I also had the shock disconnected at
its mounts so there was less interference there as well. Anyway, that's what worked
for me.
Phil Stewart
'76 Transmode, TN
