Renewing wiring on a 1977 23 ft Birchaven
Thinking of all exterior lighting to LED except headlights and adding DRL
Plan - replace flasher ( only one on this coach) with a electronic one
LEDs will be non polarity sensitive
Install a DRL-1
Include out side upper clearance light in parallel with side clearance light on front
Wire rear upper clearance light and side light as the front is wired - front is wired
Turn on - side off
Turn off - side on
Hoped for result
Engine on all running lights on
Turn signal on
Directional light flash
Side clearance lights flash
Top out board clearance light flash
Will this work? Jim
Install a DRL-1
Turn on - side off
Turn off - side on
Hoped for result
Turn signal on
Will this work? Jim
