When you are talking about the possibility of screwing up your engine with a
to lean mixture, spend a couple of dollars and have your repair shop put
their gas analyzer in the exhaust and check the mixture. Why be penny wise
and pound foolish? Engines are expensive.
>Chuck,
> While the old carburetor gives better gas mileage, are you sure it is rich
>enough to avoid engine damage? You don't want to burn any valves from
>running too lean just to pick up some MPG. It may be fine, but you should
>keep an eye on it. I would check the plugs after a trip to see what they
>look like. Fairly clean to a brownish color is good. Black/Sooty is too
>rich. Totally clean, white deposits, or a slightly burned electrode could
>all indicate a lean mixture. The plugs should be checked after a normal
>run. Shut it off as soon as you stop instead of letting it idle,
>otherwise, you will be reading the idle mixture instead of the normal
>running mixture. This is not the most accurate method of gauging your fuel
>mixture, but it should give a reasonable gauge.
> Another, even less accurate gauge would be to see how red the exhaust
>manifolds get when pulling an incline. This method would entail driving
>with the engine cover off, so BE CAREFUL if you try this method. They will
>probably get red even with the correct mixture, but if they are really
>glowing cherry red, then it is probably too lean. OTOH if they don't get
>red at all (very unlikely), then it may be too rich.
> Zak
>>oil flow and wonderful oil pressure (not a false one either) I changed to
>>the old carb today and we went 250 round trip up the coast and back. 1/4
>>tank of gas. Much better than a tank up and a tank back like last week
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
>Chuck,
> Zak
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
