Had time this morning to analyze my problem. Problem fixed. Heavy
downpour. No leaks. Happy guy. Woohoo..
The slideout out the rear is a good idea. If any one has seen some of
the class C's with it, it's pretty cool. Sealing it would be easy, as
all you would do is use the rear panel for your end cap. Seals when it
closes. Some snazzy hardware mounted under the bed. Electric switches.
Electric over hydraulic pump or electric crank style. Minimal
engineering for stress. Ignition cutoff with it extended. All that is
lost if you cannot extend is the wallkaround aspect. If I win a lottery
I do believe I will do it. Darren
Darren Paget
76 Experimental
Another Fab Day
paget
Darren Paget
76 Experimental
Another Fab Day
paget
