leaking rotating antenna shaft
Ron Clark
1,506
North Plains, OR
The rainy season approacheth.
How do I deal with a rotating antenna shaft (?) that lets water into the
coach? Does it come apart to install a new gasket, or ???
We put a tarp over the antenna last year, which stopped the leak
Or, what are the odds that it's not the shaft, but the signal wire
connector?
Thanks,
Ron C
You have to take it apart and look what is causing the leak. If it is a winegard batwing style unite that most RV dealers have repair parts. It is a very common antenna.
JR Wright
> connector?
> Thanks,
> Ron C
I should be able to supply you the parts.
On Thu, Nov 12, 2020 at 4:46 PM John Wright via Gmclist <
> JR Wright
> > On Nov 12, 2020, at 7:26 PM, rallymaster--- via Gmclist <
> > connector?
> > Thanks,
> > Ron C
http://www.gmcrvparts.com
