Neely Butler,
Before you go to the trouble of changing your A/T gasket, you may want
take a good look at the pan to see if the oil is seeping through the
aluminium material. I experienced the same leaking problem several years
back, and after trying three different types of gasket material and
silicone, I finally took a closer look as to where the oil was coming
from. It was seeping through the pours in the aluminum material and
caused "wetting" on the outside of the pan same as a leaking gasket would
cause. Some types of aluminum used in castings are very porous and have
to be "sealed" to keep them from leaking oil. The automotive industry
seals all of their aluminum castings that are used in places that have to
contain oil. They are sealed with sodium silicate "water glass" in a
vacuum oven at elevated temperatures. I have been told that one type of
aluminum A/T pans being sold for our GMCs are not sealed in this way.
They cannot be sealed after they have been subjected to oil. You may
have to return your pan and try another one or go back to the OEM pan.
Chuck Aulgur-76 Royale-CA
