knock detector and retarder
thomas g. warner
1,863
Wouldn't it be simpler and cheaper to buy the Caspro system that
automatically detects spark knock and retards the spark instead of trying to
do it manually? $169.00
>Zak
>THANKS! I do not plan on putting a 4 inch fire hose up there. It is only
>a 3/8 inch line going to the engine compartment. I am planning on using
>one of the micro-mister heads to spray a very fine mist. Now you can buy
>this same system for $249 from the Mags we all read. They supply a new
>pump and the lawn sprinkler heads plus some tubing you can buy at Lowes.
>Why not use the pump we have and maybe $ 10 worth of new parts to do
>the same thing. Now if I need this system the radiator is going to be well
>over 212 degrees so that any water that hits it as a fine mist is going to
>be changed vapor. No, I will not explode my exhaust manifolds as suggested
>by one backdoor message. Zak is right you could not drive in the rain
>if this were true. Zak I have not raced in a long time but we used to have
>a chart taped inside the tool box that told us how far we could advance
>the timing according to how much humidity was in the air. We checked
>the humidity and set the timing accordingly. If the humidity was high
>then we could push the timing up. If the radiator vaporizes the water
>then the humidity goes up in the engine compartment. A lot less
>knock.
>As to deposits. Yes, they might be a problem. I dont expect to run
>this system 24-7. It was only thought of as a problem solver for extreme
>situations. I will go to Walmart and get some CLR if I am in the boonies
>I will spray it with vinegar and wash it off after 5 Min. Yes, vinegar will
>pit the fins on then radiator------it will dissipate more heat because
>of it.
>Take Care
>Arch 76 GB IL
>> That's pretty funny :)! Now the GMC can't even be driven in the rain :)!!
>> I think that as long as Arch keeps the water to a reasonable amount and
>> mists it on the front of the radiator, that it should evaporate on the hot
>> radiator before it gets to the engine. The evaporation is where the big
>> cooling effects would come into play. There have been some companies that
>> sold systems like this in the FMCA magazine (though most were intended for
>> rear engine motorhomes which would not have
>> to worry about the problem you suggest). Another potential problem might
>> be deposits left by the water. Water can have a lot of minerals in it
>> which would be deposited on evaporation. The deposits might keep both the
>> water and the air from having direct contact with the metal which would
>> reduce the cooling. It probably would not be a real problem, but it is
>> something to consider.
>> Zak
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
