Kill Switchs and Thieves
Apr 18, 1999
114
We have a removable steering wheel.
Which I learned about from Chuck Botts.
It's hard to go very far without a steering wheel.
Bob Morris
Cortland NY 13045
74 Elganza SE
jayhawk
To:
Sent: Wednesday, June 07, 2000 12:52 PM
Subject: Re: GMC: Kill Switchs and Thieves
> What exactly do you do for a living, Mark and where were you on the night of the
> 5th???????
> > Any good thief can start any GMC with just a few clip leads. Unless you
> > have an HEI Ignition with a computer, or some complicated ignition/injection
> > arrangement I can break in and start your GMC in under 5 minutes. And if you
> > have that then I have a common tool which allows me to disable your key
> > switch in 30 seconds, then I'll start your coach and drive away without ever
> > lifting the hatch.
> > The most effective theft deterrent is a hidden gas line lock, and the
> > best of those setups is one that allows the vehicle to run for 5 minutes then
> > die. If the vehicle won't start the thief may diagnose the problem, but if it
> > dies in the street he isn't going to stick around.
> > Lock 'em up!!
> > Mark A
